[Qgis-user] New crowdfunding campaign: point clouds and 3D improvements in QGIS
Nyall Dawson nyall.dawson at gmail.com
Tue Sep 27 22:35:56 PDT 2022
On Tue, 27 Sept 2022 at 16:40, Saber Razmjooei
<saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi Andreas,
> Many thanks for your email.
> @Nyall Dawson can comment on that, but I think it should be possible to add SVG format too as an option to export elevation profiles to.
The issue with including SVG export is the time-old limitation in Qt
regarding SVG exports when clipping paths are present. We use clipping
paths heavily in the elevation plots, so if we exported these to SVG
then the clipping would be ignored and the results would be an
unusable mess.
(I'll revisit this when the issue is resolved in Qt, as the actual
QGIS part of SVG exports is trivial)
Nyall
> Kind regards
> Saber
> On Tue, 27 Sept 2022 at 08:25, Andreas Neumann <andreas at qgis.org> wrote:
>> Hi Saber,
>> Very good. Hopefully it will be another successful campaign.
>> A question on the export of the profile: CSV and DXF is mentioned. Wouldn't it also make sense to add SVG export, so the profile could be exported to Inkscape/Illustrator? I know, it is already possible to export a layout to SVG (and with the new enhancement, the profile can then be part of a layout), but it would be convenient, being able to export to SVG without having to create a layout first. Not sure, how much effort this would mean?
>> I will help to spread the word!
>> Andreas
>> On Mon, 26 Sept 2022 at 17:43, Saber Razmjooei via Qgis-user <qgis-user at lists.osgeo.org> wrote:
>>> Dear all,
>>> As you know, in the past couple of years, we (Lutra, North Road and https://hobu.co/) added support point clouds and developed several new 3D features to QGIS (e.g. Profile tool).
>>> For the next round of crowdfunding, after feedback by several user groups and organizations, we decided to bring processing of point clouds to QGIS. In addition, there will be several enhancements to the profile tool and 3D maps. For more information, see:
>>> https://www.lutraconsulting.co.uk/crowdfunding/pointcloud-processing-qgis/
>>> Your help is needed to make this happen. Please support our crowdfunding campaign by filling out the pledge form. If you are from a larger organisation and require extra information to contribute to the campaign, please contact me.
>>> Kind regards
>>> Saber
>>> Saber Razmjooei
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
> Saber Razmjooei
