[Qgis-user] PR review needed
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Tue Sep 27 23:59:51 PDT 2022
Thank you! I had that in my tabs to try out and did so yesterday. It is
impressive but of course requires the user to manually install some
packages (which is a HUGE blocker for 99% of users) and is missing
integration in the script editor. I will probably still use it for
myself though so thank you very much!
Am 27.09.22 um 16:43 schrieb Alessandro Pasotti:
> You may want to check this out (Works For Me (TM)):
> https://plugins.qgis.org/plugins/IPyConsole/ autocompletion and other
> IPython features works just fine.
> On Tue, Sep 27, 2022 at 4:37 PM Johannes Kröger (WhereGroup) via
> Qgis-user <qgis-user at lists.osgeo.org> wrote:
>     > jedi autocompletion
>     I can't say just how awesome it would be to have some "proper"
>     autocompletion in the console and editor. One that knows about the
>     actual object it is used on instead of suggesting random text
>     string matches from anywhere in its database.
>     Honestly, this would make learning and teaching Python and the
>     PyQGIS API infinitely easier and fun.
>     Seeing the GIFs on https://yoannqdq.github.io/qgis-better-editor/
>     makes me jealous of the people who used your plugin when it was
>     working in the older versions. Wow!
>     Cheers, Hannes
>     Am 27.09.22 um 14:48 schrieb Yoann QUENACH DE QUIVILLIC via Qgis-user:
>>     Hi everyone,
>>     Some 2 years ago, I was frustrated with some of the features of
>>     the embedded python console, so I developed a plugin called
>>     Better Editor (https://plugins.qgis.org/plugins/bettereditor)
>>     which offered smart brackets / parenthesis, better toggle comment
>>     action, code formatting with black, jedi autocompletion...
>>     I was quite happy with it, but unfortunately, this plugin was
>>     heavily reliant on monkey patching existing classes, so it broke
>>     very often across QGIS versions.
>>     I'm now trying to backport some of the features I developed in
>>     the plugin in QGIS, starting (small) with the toggle comment action.
>>     I'd be really thankful if a QGIS maintainer could take the time
>>     to review my PR:
>>     https://github.com/qgis/QGIS/pull/50341
>>     Regards,
>>     *Yoann Quenach de Quivllic*
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> QCooperative: www.qcooperative.net <https://www.qcooperative.net>
> ItOpen: www.itopen.it <http://www.itopen.it>
Johannes Kröger / GIS-Entwickler/-Berater
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220928/4a9bfcb9/attachment.htm>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220928/4a9bfcb9/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220928/4a9bfcb9/attachment.sig>
