[Qgis-user] PR review needed
Alessandro Pasotti
apasotti at gmail.com
Wed Sep 28 05:46:02 PDT 2022
Yes, I know pip install is quite a barrier, I've been using this plugin for
years and never used the standard console again.
I guess this is more a personal project than a plugin for a wider audience.
I'm glad that you've found it useful.
Regards.
On Wed, Sep 28, 2022 at 8:59 AM Johannes Kröger (WhereGroup) <
johannes.kroeger at wheregroup.com> wrote:
> Thank you! I had that in my tabs to try out and did so yesterday. It is
> impressive but of course requires the user to manually install some
> packages (which is a HUGE blocker for 99% of users) and is missing
> integration in the script editor. I will probably still use it for myself
> though so thank you very much!
> Am 27.09.22 um 16:43 schrieb Alessandro Pasotti:
> You may want to check this out (Works For Me (TM)):
> https://plugins.qgis.org/plugins/IPyConsole/ autocompletion and other
> IPython features works just fine.
> On Tue, Sep 27, 2022 at 4:37 PM Johannes Kröger (WhereGroup) via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
>> > jedi autocompletion
>> I can't say just how awesome it would be to have some "proper"
>> autocompletion in the console and editor. One that knows about the actual
>> object it is used on instead of suggesting random text string matches from
>> anywhere in its database.
>> Honestly, this would make learning and teaching Python and the PyQGIS API
>> infinitely easier and fun.
>> Seeing the GIFs on https://yoannqdq.github.io/qgis-better-editor/ makes
>> me jealous of the people who used your plugin when it was working in the
>> older versions. Wow!
>> Cheers, Hannes
>> Am 27.09.22 um 14:48 schrieb Yoann QUENACH DE QUIVILLIC via Qgis-user:
>> Hi everyone,
>> Some 2 years ago, I was frustrated with some of the features of the
>> embedded python console, so I developed a plugin called Better Editor (
>> https://plugins.qgis.org/plugins/bettereditor) which offered smart
>> brackets / parenthesis, better toggle comment action, code formatting with
>> black, jedi autocompletion...
>> I was quite happy with it, but unfortunately, this plugin was heavily
>> reliant on monkey patching existing classes, so it broke very often across
>> QGIS versions.
>> I'm now trying to backport some of the features I developed in the plugin
>> in QGIS, starting (small) with the toggle comment action.
>> I'd be really thankful if a QGIS maintainer could take the time to review
>> my PR:
>> https://github.com/qgis/QGIS/pull/50341
>> Regards,
>> *Yoann Quenach de Quivllic*
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
> Johannes Kröger / GIS-Entwickler/-Berater
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:https://wheregroup.com/blog/
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
Alessandro Pasotti
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220928/318d8086/attachment-0001.htm>
