[Qgis-user] MBTiles have wrong georeferencing
Namotec, Eberbach am Neckar 2019 at namotec.de
Thu Apr 6 08:38:42 PDT 2023
I want to georeference a very large SQlite file (MBTiles) and include
it in QGIS3. The tiles can be displayed with QGIS, but the location is
not correct.
What is the best strategy to georeference MBTiles?
According to manual MBTiles does not accept worldfile (wld).
Reference: https://gdal.org/drivers/raster/mbtiles.html
For correct projection scaling and XY shift is enough.
Is it standard to create a Custom Coordinate Reference System (CRS) in
such a case?
Or is GDAL suitable to make a coordinate transformation?
Does anyone know a manual? I am grateful for any hint.
Regards,
Christian Naujoks
gdalinfo:
Driver: MBTiles/MBTiles
Files: map_z6-18.mbtiles
Size is 2097152, 2097152
Coordinate System is:
PROJCS["WGS 84 / Pseudo-Mercator",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Mercator_1SP"],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["X",EAST],
    AXIS["Y",NORTH],
    EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
+wktext  +no_defs"],
    AUTHORITY["EPSG","3857"]]
Origin = (0.000000000000000,7514065.628809665329754)
Pixel Size = (1.194328566955879,-1.194328566955879)
Metadata:
  ZOOM_LEVEL=17
  name=Unnamed map
  type=baselayer
  version=1.2
  format=jpg
  bounds=0.00000000,40.97989807,22.50000000,55.77657302
  attribution=
  scheme=tms
  minzoom=5
  maxzoom=17
  center=11.25000000, 48.37823554, 5
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (       0.000, 7514065.629) (  0d 0' 0.01"E, 55d46'35.66"N)
Lower Left  (       0.000, 5009377.086) (  0d 0' 0.01"E, 40d58'47.63"N)
Upper Right ( 2504688.543, 7514065.629) ( 22d30' 0.00"E, 55d46'35.66"N)
Lower Right ( 2504688.543, 5009377.086) ( 22d30' 0.00"E, 40d58'47.63"N)
Center      ( 1252344.271, 6261721.357) ( 11d15' 0.00"E, 48d55'21.00"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
  Overviews: 1048576x1048576, 524288x524288, 262144x262144,
131072x131072, 65536x65536, 32768x32768, 16384x16384, 8192x8192,
4096x4096, 2048x2048, 1024x1024, 512x512
  Mask Flags: PER_DATASET ALPHA
  Overviews of mask band: 1048576x1048576, 524288x524288,
262144x262144, 131072x131072, 65536x65536, 32768x32768, 16384x16384,
8192x8192, 4096x4096, 2048x2048, 1024x1024, 512x512
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Band 4 Block=256x256 Type=Byte, ColorInterp=Alpha
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230406/ab4c329b/attachment.htm>
More information about the QGIS-User mailing list
