[Qgis-user] Question Re: Map Exporting (How to keep Map
Thayer Young
thayeray at yahoo.com
Thu Apr 6 10:47:27 PDT 2023
This GIS Stackexchange question and answer should help you:
https://gis.stackexchange.com/questions/312150/why-are-labels-and-looks-different-between-print-layout-and-map-canvas-at-same-s
-Thayer
On Thursday, April 6, 2023 at 11:40:51 AM EDT, Michael Raymond <michael.raymond at northnorthants.gov.uk> wrote:
Thank you, I am experimenting with changing the map canvas now. You’re correct as well, I am looking into getting an updated version of QGis also. With an updated version of QGis what is the normal function one would otherwise use to do this?
Regards,
Mike
Sent: 06 April 2023 15:56
To: qgis-user at lists.osgeo.org; Michael Raymond <Michael.Raymond at northnorthants.gov.uk>
Subject: Re: Question Re: Map Exporting (How to keep Map
[CAUTION: EXTERNAL EMAIL]This email originated from outside of the organisation. Do not click links or open attachments unless you recognise the sender and know the content is safe.
Hi Mike,
Firstly I would say that you should seriously think about updating your QGIS, as 2.18.28 is very old. The current long term release version is 3.28.5. QGIS 3 has many improvements over 2, and has been in development for long enough that the bugs are mostly worked out. I can not remember your specific issue from 2, but I know that labeling has been much improved recently in 3, with very good, but not necessarily perfect, correspondence between how labels look in the layout and how they look on exported pdf's and images, the difference is mostly just that occasionally a label will not shows up on an export when it is present in the layout. I have not noticed differences in size or font. The correspondence between labels in the map canvas and the layout/print is much improved also.
You may want to try adjusting your map canvas scale to match the scale in the layout. I have found that there is usually a sweet spot where the map canvas labels display almost exactly the same as in the layout.
-Thayer
On Thursday, April 6, 2023 at 06:14:49 AM EDT,qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
From: Michael Raymond <Michael.Raymond at northnorthants.gov.uk>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Question Re: Map Exporting (How to keep Map
labels the same size when exporting Map as pdf or image via composer
manager)
Message-ID:
<CWXP123MB5785B6D324E95295D1E9FF1FB9919 at CWXP123MB5785.GBRP123.PROD.OUTLOOK.COM>
Content-Type: text/plain; charset="utf-8"
Good morning,
I?m messaging as, when I export my Map as pdf (or as image) the labels on the Map are smaller than what is shown when I preview after ?drawing the map? in the composer manager.
At present I can remedy this to an extent by lowering the MAP dpi in composer manager, but this obviously comes at the cost of the labels teetering on illegibility (which is just another version of the issue I?m trying to remedy in the first place). I understand a better remedy might be a case of converting the raster layer (which I am only presuming is the underlying map that I?m having issues with) ?from pixels to points? (or vice versa).
However, I have QGis version 2.18.28 and there doesn?t appear to be any explicit function pertaining to this, and indeed said remedy may in fact be something different entirely. Am open to any alternative resolutions if so, hope you can help?
Note: Have attached a version of the Map which I?ve managed to sort based on lowering the dpi, which as you can see works ok but it would be preferred to have it clearer.
Regards,
Mike Raymond ? Place Information Officer
Performance, Intelligence and Partnerships
North Northamptonshire Council
Cedar Drive, Thrapston, Northants NN14 4LZ
T: 0300 126 3000 | DD: 07423799714
Twitter:@NNorthantsC
Facebook:@NorthNorthants
Web:www.northnorthants.gov.uk<http://www.northnorthants.gov.uk/>
Any views expressed in this email are those of the individual sender and are not necessarily those of North Northamptonshire Council unless explicitly stated.
This email (including any attachments) may contain confidential or privileged information and is intended solely for the use of the individual or entity to whom it is addressed. Any confidential, sensitive or protectively marked material must be handled accordingly.
If you are not the intended recipient you must not disclose, distribute, copy, print or rely on any of the information contained in the email or attachments, and all copies must be deleted immediately. If you do receive this email in error, please notify the sender immediately and note that confidentiality or privilege is not waived or lost.
North Northamptonshire Council may monitor the contents of emails sent and received via its network for the purposes of ensuring compliance with relevant legislation and the Council’s policies and procedures. All such monitoring will take place in accordance with relevant legislation including privacy and data protection legislation. For details of how North Northamptonshire Council uses personal information please see the Council’s website.
North Northamptonshire Council has scanned this email and attachments for viruses but does not accept any responsibilities for viruses once this email has been transmitted. You should therefore carry out your own anti-virus checks before opening any documents.
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
This email has been scanned for viruses and malware, and may have been automatically archived by Mimecast, a leader in email security and cyber resilience. Mimecast integrates email defenses with brand protection, security awareness training, web security, compliance and other essential capabilities. Mimecast helps protect large and small organizations from malicious activity, human error and technology failure; and to lead the movement toward building a more resilient world. To find out more, visit our website.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230406/a7c74a3f/attachment.htm>
More information about the QGIS-User
