[Qgis-user] Question Re: Map Exporting (How to keep Map
Thayer Young thayeray at yahoo.com
Thu Apr 6 07:55:47 PDT 2023
 Hi Mike,
Firstly I would say that you should seriously think about updating your QGIS, as 2.18.28 is very old. The current long term release version is 3.28.5. QGIS 3 has many improvements over 2, and has been in development for long enough that the bugs are mostly worked out. I can not remember your specific issue from 2, but I know that labeling has been much improved recently in 3, with very good, but not necessarily perfect, correspondence between how labels look in the layout and how they look on exported pdf's and images, the difference is mostly just that occasionally a label will not shows up on an export when it is present in the layout. I have not noticed differences in size or font. The correspondence between labels in the map canvas and the layout/print is much improved also.
You may want to try adjusting your map canvas scale to match the scale in the layout. I have found that there is usually a sweet spot where the map canvas labels display almost exactly the same as in the layout.
-Thayer
    On Thursday, April 6, 2023 at 06:14:49 AM EDT, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote: From: Michael Raymond <Michael.Raymond at northnorthants.gov.uk>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Question Re: Map Exporting (How to keep Map
    labels the same size when exporting Map as pdf or image via composer
    manager)
Message-ID:
    <CWXP123MB5785B6D324E95295D1E9FF1FB9919 at CWXP123MB5785.GBRP123.PROD.OUTLOOK.COM>
Content-Type: text/plain; charset="utf-8"
Good morning,
I?m messaging as, when I export my Map as pdf (or as image) the labels on the Map are smaller than what is shown when I preview after ?drawing the map? in the composer manager.
At present I can remedy this to an extent by lowering the MAP dpi in composer manager, but this obviously comes at the cost of the labels teetering on illegibility (which is just another version of the issue I?m trying to remedy in the first place). I understand a better remedy might be a case of converting the raster layer (which I am only presuming is the underlying map that I?m having issues with) ?from pixels to points? (or vice versa).
However, I have QGis version 2.18.28 and there doesn?t appear to be any explicit function pertaining to this, and indeed said remedy may in fact be something different entirely. Am open to any alternative resolutions if so, hope you can help?
Note: Have attached a version of the Map which I?ve managed to sort based on lowering the dpi, which as you can see works ok but it would be preferred to have it clearer.
Regards,
Mike Raymond ? Place Information Officer
Performance, Intelligence and Partnerships
North Northamptonshire Council
Cedar Drive, Thrapston, Northants NN14 4LZ
T: 0300 126 3000 | DD:  07423799714
Twitter:@NNorthantsC
Facebook:@NorthNorthants
Web: www.northnorthants.gov.uk<http://www.northnorthants.gov.uk/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230406/7ceab96d/attachment.htm>
More information about the QGIS-User mailing list
