[Qgis-user] [pyqgis] setSubsetXXX for intersection?
andrea antonello
andrea.antonello at gmail.com
Wed Apr 12 01:44:13 PDT 2023
Thanks a lot Johannes, very appreciated,
diving directly into your links.
Best,
Andrea
On Wed, Apr 12, 2023 at 10:13 AM Johannes Kröger (WhereGroup) <
johannes.kroeger at wheregroup.com> wrote:
> Hey Andrea,
> you can do it *if* your data source (or rather the provider that QGIS uses
> for your data source) supports spatial queries for the provider feature
> filtering.
> Our "Räumlicher Filter" plugin does exactly that using setSubsetString :))
> - https://github.com/WhereGroup/spatial_filter
> - https://plugins.qgis.org/plugins/spatial_filter/
> Try it and look at the resulting filter queries or check how we construct
> the filter strings:
> https://github.com/WhereGroup/spatial_filter/blob/e77abb9830f5d46073239b8e7376c52a69046223/filters.py#L14
> https://github.com/WhereGroup/spatial_filter/blob/e77abb9830f5d46073239b8e7376c52a69046223/filters.py#L45
> As of now, the plugin supports it for PostGIS, GPKG and Spatialite layers
> . It probably is easy to adapt for other geospatial databases too.
> Cheers, Hannes
> Am 12.04.23 um 09:35 schrieb andrea antonello via QGIS-User:
> Hello,
> I was wondering if in pyqgis there is a way to load a layer to show only
> features that intersect a certain geometry. I see the setSubsetString for
> sql like queries, but no way to do this with geometries.
> Similar to this (but only applied to iterations using getFeatures), I was
> wondering if with QgsFeatureRequest and expressions there is a way to
> create a geometry intersection filter (I saw the setFilterRect).
> Thanks a lot for any hint,
> Andrea
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Johannes Kröger / GIS-Entwickler/-Berater
> Aufwind durch Wissen!
> Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230412/c9bc2414/attachment.htm>
More information about the QGIS-User
