[Qgis-user] [pyqgis] setSubsetXXX for intersection?
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Wed Apr 12 01:13:28 PDT 2023
Hey Andrea,
you can do it *if* your data source (or rather the provider that QGIS
uses for your data source) supports spatial queries for the provider
feature filtering.
Our "Räumlicher Filter" plugin does exactly that using setSubsetString :))
  * https://github.com/WhereGroup/spatial_filter
  * https://plugins.qgis.org/plugins/spatial_filter/
Try it and look at the resulting filter queries or check how we
construct the filter strings:
  * https://github.com/WhereGroup/spatial_filter/blob/e77abb9830f5d46073239b8e7376c52a69046223/filters.py#L14
  * https://github.com/WhereGroup/spatial_filter/blob/e77abb9830f5d46073239b8e7376c52a69046223/filters.py#L45
As of now, the plugin supports it for PostGIS, GPKG and Spatialite
layers . It probably is easy to adapt for other geospatial databases too.
Cheers, Hannes
Am 12.04.23 um 09:35 schrieb andrea antonello via QGIS-User:
> Hello,
> I was wondering if in pyqgis there is a way to load a layer to show
> only features that intersect a certain geometry. I see
> the setSubsetString for sql like queries, but no way to do this with
> geometries.
> Similar to this (but only applied to iterations using getFeatures), I
> was wondering if with QgsFeatureRequest and expressions there is a way
> to create a geometry intersection filter (I saw the setFilterRect).
> Thanks a lot for any hint,
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230412/89493ab6/attachment.htm>
More information about the QGIS-User mailing list
