[Qgis-user] Copying collected shape file to another shape file
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Apr 18 10:35:59 PDT 2023
just a wild guess (as I do not work with shape files anymore):
Did you check the properties of the target layer?
Is it a MultiPolygon-Layer or just a Polygon-Layer?
It might be possible that, when the target layer was created outside of
QGIS, that it is plain Polygon, while QGIS always creates Multipolygon
layers.
But I might be wrong
Cheers,
Bernd
Am 18.04.23 um 11:35 schrieb Riccardo via QGIS-User:
> Good morning to all,
> I need a hint about using Qgis, I hope someone of you could answer me.
> I created an area shape file using the collect/multipart operation and
> in such a way as to associate several areas to the same tabular record.
> I need to copy this shape file to another shape file for a requirement
> of a standard delivery.
> Unfortunately, the shape file where I copy my original shape file
> collected doesn't keep the collect property, and so I have a copied
> shape file with every area associated to a unique record and not a a
> shape file with more area associated to a unique record as the original
> shape file.
> How can I conserve this property during the copy between two shape files?
> Many thanks!
> Best Regards.
> Riccardo.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
