[Qgis-user] Github Access Problems
Adam Nielsen
a.nielsen at shikadi.net
Wed Apr 19 05:16:37 PDT 2023
> I understand a lot of organisations have migrated off Github since
> Microsoft took it over for various reasons.
A few did in the early days for ideological reasons, but Microsoft have
actually done a surprisingly good job (so far) of just leaving GitHub
alone, so it seems to be more popular than ever.
> I do not know if the Qgis project has considered this option, but it
> seems to me that there is nothing I can do to solve what appears to
> be ongoing issues between MS and Google and therefore there is no
> obvious other solution to address the problems I have with my login,
> other than changing to a non-Google email account.
This is one of the drawbacks of relying on a third party for a service
that you deem critical - and one of the reasons why I run my own e-mail
server. Sure it's a lot more work, but I don't have to worry about the
whims of a corporation I have no control over.
Having said that, I did not realise GitHub offered e-mail as a 2FA
option. I have only ever used TOTP, which is an "offline" method as it
doesn't require Internet access to work. If you're having issues with
e-mails taking too long to get delivered, I suggest switching to TOTP
for 2FA as per GitHub's guidelines:
https://docs.github.com/en/authentication/securing-your-account-with-two-factor-authentication-2fa/configuring-two-factor-authentication
You don't have to use the apps they recommend. Personally I started
off with Google Authenticator but as I wanted my codes on multiple
devices, I ended up switching to the command-line "oathtool" program
from the OATH Toolkit (https://www.nongnu.org/oath-toolkit/). Whenever
I need to log in to GitHub, I have a script that runs
"oathtool --totp -b 12345" where 12345 is the key GitHub gave me when I
set up TOTP, and the program spits out a six digit code. I enter that
code into the GitHub login page and I'm in, no need for e-mail.
Cheers,
Adam.
More information about the QGIS-User
