[Qgis-user] PyQGIS to set masked symbol layer and mask source in ver. 3.30
Anne B. Nilsen
anne.b.nilsen at nibio.no
Wed Apr 26 04:52:29 PDT 2023
Thanks to the answer to this post https://gis.stackexchange.com/questions/447362/pyqgis-to-set-masked-symbol-layer-and-mask-source
I managed to set the mask layer in QGIS version 3.28.
The code is not working In ver. 3.30 due to a change in the QgsSymbolLayerReference class.
However I'm not able to change the original code so it fits with the new specification
I just don't understand how to set the input parameters to fulfil the requirements in https://qgis.org/pyqgis/3.30/core/QgsSymbolLayerReference.html#qgis.core.QgsSymbolLayerReference
# Set masked symbol layers : setMaskedSymbolLayers(self, maskedLayers: Iterable[QgsSymbolLayerReference])
fileName = "./gpkg/karplantehoyder.gpkg"
layer = QgsVectorLayer(fileName, "hoyder", "ogr")
layer.loadNamedStyle('./qml/n5hoyder.qml') # Load qml
QgsProject.instance().addMapLayer(layer, False) # Add layer False to be able
root.insertLayer(4,layer) # to specify a custom position
label_settings = layer.labeling().settings() # Get current settings of the layer
text_format = label_settings.format() # Get text format of the settings
# old code (working in 3.28)
# text_format.mask().setMaskedSymbolLayers([QgsSymbolLayerReference(layer.id(), QgsSymbolLayerId("", 0))]) # set masked symbol layers *****
# -- New code
linesymbol = QgsLineSymbol()
lyr = linesymbol.symbolLayer(0) # Trying to get the id of the line layer (hoyder)
text_format.mask().setMaskedSymbolLayers([layer.id(), lyr.id()]) # set masked symbol layers - not working
label_settings.setFormat(text_format) # set format
layer.labeling().setSettings(label_settings) # set settings
layer.saveStyleToDatabase(layer.name(),'style n5hoyder',True,'') # Save style in gpkg
Anyone who knows how I should write the code marked with *****?
Kind regards
Anne
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230426/4fd40506/attachment.htm>
More information about the QGIS-User
