[Qgis-user] PyQGIS to set masked symbol layer and mask source in ver. 3.30
Julien Cabieces
julien.cabieces at oslandia.com
Wed Apr 26 09:01:41 PDT 2023
I changed the way we referenced symbol layer to make it more simple and
robust. Now, symbol layer have a generated unique id so it's easier to reference
each of them (instead of a path of indices in the symbol layers tree before).
I see 2 solutions here:
1. You keep your old references and call
QgsProjectFileTransform.fixOldSymbolLayerReferences() on your layers
2. You change the way you create the references. here[0] is an example on
how you can create QgsSymbolLayerReference.
I would favor solution 2 because you wouldn't rely on deprecated method
and so you would be more future proof for when we eventually drop these
methods.
Regards,
Julien
[0] https://github.com/qgis/QGIS/pull/50786/files#diff-c7f779c945b0e9c401ddb964691ec0d6a07c6c3fcfca0e3db146f97aec2d17e2R177
> Thanks to the answer to this post https://gis.stackexchange.com/questions/447362/pyqgis-to-set-masked-symbol-layer-and-mask-source
> I managed to set the mask layer in QGIS version 3.28.
> The code is not working In ver. 3.30 due to a change in the QgsSymbolLayerReference class.
> However I’m not able to change the original code so it fits with the new specification
> I just don’t understand how to set the input parameters to fulfil the requirements in
> https://qgis.org/pyqgis/3.30/core/QgsSymbolLayerReference.html#qgis.core.QgsSymbolLayerReference
> # Set masked symbol layers : setMaskedSymbolLayers(self, maskedLayers: Iterable[QgsSymbolLayerReference])
> fileName = "./gpkg/karplantehoyder.gpkg"
> layer = QgsVectorLayer(fileName, "hoyder", "ogr")
> layer.loadNamedStyle('./qml/n5hoyder.qml') # Load qml
> QgsProject.instance().addMapLayer(layer, False) # Add layer False to be able
> root.insertLayer(4,layer) # to specify a custom position
> label_settings = layer.labeling().settings() # Get current settings of the layer
> text_format = label_settings.format() # Get text format of the settings
> # old code (working in 3.28)
> # text_format.mask().setMaskedSymbolLayers([QgsSymbolLayerReference(layer.id(), QgsSymbolLayerId("", 0))]) # set masked symbol layers *****
> # -- New code
> linesymbol = QgsLineSymbol()
> lyr = linesymbol.symbolLayer(0) # Trying to get the id of the line layer (hoyder)
> text_format.mask().setMaskedSymbolLayers([layer.id(), lyr.id()]) # set masked symbol layers – not working
> label_settings.setFormat(text_format) # set format
> layer.labeling().setSettings(label_settings) # set settings
> layer.saveStyleToDatabase(layer.name(),'style n5hoyder',True,'') # Save style in gpkg
> Anyone who knows how I should write the code marked with *****?
> Kind regards
> Anne
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Julien Cabieces
Senior Developer at Oslandia
09.72.52.52.76
More information about the QGIS-User
