[Qgis-user] setting map scale
Stewart Holt stewartbholt at gmail.com
Wed Apr 26 09:16:42 PDT 2023
Yes, I have seen that problem in 3.30.1. (I have not installed 3.30.0)
The problem exists even before opening a project. When I attempted to
create a new profile, QGIS became unresponsive. After a minute or so, I
killed the process, restarted QGIS, and the problem still existed. I think
it was using the new profile. To define what the symptom is in more
detail... All of the configured scales are listed horizontally in the
dropdown which is 8 or 10 inches wide. They are separated by commas and
highlighted blue. With a project open, I can type a scale into the box and
it correctly accepts it and uses it. This must not be a widespread problem,
but in ruling out the profile, I haven't thought of any other change to
try. I have continued to use 3.28 as a result.
Stewart
On Wed, Apr 26, 2023 at 11:31 AM Lester Anderson via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello all,
> Not sure if this is a bug, but when trying to select the map scale from
> the status bar (1) It is not expanded to see properly and (2) Clicking the
> down button causes QGIS to crash.
> Issue: Version 3.30.1
> Anyone el;se see this problem?
> 3.26.3 Shows scale fine
> 3.30.1 Does not show scale properly
> Lester
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230426/91e28da7/attachment.htm>
More information about the QGIS-User mailing list
