[Qgis-user] setting map scale
Andrea Giudiceandrea
andreaerdna at libero.it
Wed Apr 26 15:10:57 PDT 2023
> Lester Anderson arctica1963 at gmail.com
> Wed Apr 26 08:29:04 PDT 2023
> Not sure if this is a bug, but when trying to select the map scale from the
> status bar (1) It is not expanded to see properly and (2) Clicking the down
> button causes QGIS to crash.
> Issue: Version 3.30.1
Hi Lester,
the bug that caused the crash has been reported several times [1] and
has been already fixed after various attempts [2].
The fixes will land in the upcoming QGIS 3.30.2 release.
In the meantime, you can workaround the issue even in QGIS 3.30.1 by
going to "Settings->Options..." -> "Map Tools" -> "Predefined Scales"
and click on the "Reset to default scales" button in order to restore
the predefined scales, populate the map scale listbox and avoid the crash.
Best regards.
Andrea
[1] see e.g. https://github.com/qgis/QGIS/issues/52383
[2] https://github.com/qgis/QGIS/pull/52427 ,
https://github.com/qgis/QGIS/pull/52414 ,
https://github.com/qgis/QGIS/pull/52511 ,
https://github.com/qgis/QGIS/pull/52580
More information about the QGIS-User
