[Qgis-user] setting map scale
Lester Anderson arctica1963 at gmail.com
Thu Apr 27 00:14:34 PDT 2023
Thanks for the update and workaround for the problem.
On Wed, 26 Apr 2023 at 23:11, Andrea Giudiceandrea via QGIS-User <
> > Wed Apr 26 08:29:04 PDT 2023
> > Not sure if this is a bug, but when trying to select the map scale from
> the
> > status bar (1) It is not expanded to see properly and (2) Clicking the
> down
> > button causes QGIS to crash.
> > Issue: Version 3.30.1
> Hi Lester,
> the bug that caused the crash has been reported several times [1] and
> has been already fixed after various attempts [2].
> The fixes will land in the upcoming QGIS 3.30.2 release.
> In the meantime, you can workaround the issue even in QGIS 3.30.1 by
> going to "Settings->Options..." -> "Map Tools" -> "Predefined Scales"
> and click on the "Reset to default scales" button in order to restore
> the predefined scales, populate the map scale listbox and avoid the crash.
> Best regards.
> Andrea
> [1] see e.g. https://github.com/qgis/QGIS/issues/52383
> [2] https://github.com/qgis/QGIS/pull/52427 ,
> https://github.com/qgis/QGIS/pull/52414 ,
> https://github.com/qgis/QGIS/pull/52511 ,
> https://github.com/qgis/QGIS/pull/52580
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230427/e1476919/attachment.htm>
More information about the QGIS-User mailing list
