[Qgis-user] WhiteTools error
Dario C dario955i at gmail.com
Fri Apr 28 13:20:23 PDT 2023
Ok ok, I have found what you said. Solved!
Thank you very much
Il Ven 28 Apr 2023, 22:14 Dario C <dario955i at gmail.com> ha scritto:
> Thank you Andrea.
> I tried to unable all the installed plugin but still have this message
> once I press plugins manager button
> Sorry, I guess it's me I don't understand your advises
> Regards,
> Dario
> Il Ven 28 Apr 2023, 21:52 Andrea Giudiceandrea via QGIS-User <
>> > Fri Apr 28 04:39:25 PDT 2023
>> > I have this error if I open Plugins panel or general settings:
>> > [image: image.png]
>> > even if I uninstall whitetools from installed plugins.
>> Hi Dario,
>> the issue is not due to the plugin "WhiteTools" itself, so disabling or
>> uninstalling it does not prevent the error message to show up.
>> The issue is due to the fact that the plugin repository that you have
>> added in the QGIS Plugin Mangater with URL
>> https://plugins.bruy.me/plugins/plugins.xml and name "WhiteBox" is not
>> available.
>> In order to avoid the error message to show up, you need to Delete or
>> disable such plugin repository from the Plugin Manager settings.
>> Best regards.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230428/2b57d971/attachment.htm>
More information about the QGIS-User mailing list
