[Qgis-user] WhiteTools error
Dario C
dario955i at gmail.com
Fri Apr 28 13:14:11 PDT 2023
Thank you Andrea.
I tried to unable all the installed plugin but still have this message once
I press plugins manager button
Sorry, I guess it's me I don't understand your advises
Regards,
Dario
Il Ven 28 Apr 2023, 21:52 Andrea Giudiceandrea via QGIS-User <
qgis-user at lists.osgeo.org> ha scritto:
> > Dario C dario955i at gmail.com
> > Fri Apr 28 04:39:25 PDT 2023
> > I have this error if I open Plugins panel or general settings:
> > [image: image.png]
> > even if I uninstall whitetools from installed plugins.
> Hi Dario,
> the issue is not due to the plugin "WhiteTools" itself, so disabling or
> uninstalling it does not prevent the error message to show up.
> The issue is due to the fact that the plugin repository that you have
> added in the QGIS Plugin Mangater with URL
> https://plugins.bruy.me/plugins/plugins.xml and name "WhiteBox" is not
> available.
> In order to avoid the error message to show up, you need to Delete or
> disable such plugin repository from the Plugin Manager settings.
> Best regards.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230428/937120a9/attachment.htm>
More information about the QGIS-User
