[Qgis-user] QGIS3 quits after PyQt Script 2 run
Ludwig Kniprath
ludwig at kni-online.de
Wed Aug 16 12:01:38 PDT 2023
Hi Julierme,
I think Your problem is, that You try to create a new application with
"app = QApplication(sys.argv)" inside a running QGis, which already is a
running Qt-application.
Simplified code should perform without crash:
import sys
from PyQt5.QtCore import (QSize,Qt)
from PyQt5.QtWidgets import (QApplication, QWidget, QPushButton,
QMainWindow)
class MainWindow(QMainWindow):
def _init_(self):
super()._init_()
self.setWindowTitle("My App")
button = QPushButton("Press Me!")
self.setCentralWidget(button)
self.setFixedSize(QSize(400,300))
window = MainWindow()
window.show()
hth
Ludwig
Am 16.08.23 um 19:15 schrieb 1520 gis via QGIS-User:
> Hi all,
> I wrote the PyQt script below and I am running it through QGIS3. When
> I run it for the first time after opening it in QGIS3, the
> application's window pops up smoothly. However, when I close the
> window and run the script, QGIS3 readily quits. That may be something
> related to the event loop, but I'm unsure and don't know how to stop
> the QGIS3 shutdown for the subsequent runs. Any hint on how to fix
> this issue will be very appreciated.
> import sys
> Qt)
> QWidget,
> QPushButton,
> QMainWindow)
> def _init_(self):
> super()._init_()
> window.show()
> app.exec()
> *Julierme G Pinheiro*
> *SDI Expert & Geoprocessing Specialist*
> Phone: +55 61 99994-3569
> Website: GIS
> <https://www.udemy.com/course/qgis-server-para-iniciantes-instalacao-e-configuracao/>
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230816/c23f2573/attachment.htm>
More information about the QGIS-User
