[Qgis-user] QGIS3 quits after PyQt Script 2 run
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Aug 16 19:14:58 PDT 2023
Hi Ludwig,
Thank you very much for your reply. You're right, QGIS stopped crashing,
but now the button widget is not being carried out by the application
window and neither the methods are working properly like the
self.setFixedSize(QSize(400,300)). I am sending a window screenshot in
attachment.
I appreciated your time and help.
Kind regards
Julierme
On Wed, Aug 16, 2023 at 4:07 PM Ludwig Kniprath via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Julierme,
> I think Your problem is, that You try to create a new application with
> "app = QApplication(sys.argv)" inside a running QGis, which already is a
> running Qt-application.
> Simplified code should perform without crash:
> import sys
> from PyQt5.QtCore import (QSize,Qt)
> from PyQt5.QtWidgets import (QApplication, QWidget, QPushButton,
> QMainWindow)
> class MainWindow(QMainWindow):
>     def _init_(self):
>         super()._init_()
>         self.setWindowTitle("My App")
>         button = QPushButton("Press Me!")
>         self.setCentralWidget(button)
> window = MainWindow()
> window.show()
> hth
> Ludwig
> Am 16.08.23 um 19:15 schrieb 1520 gis via QGIS-User:
> Hi all,
> I wrote the PyQt script below and I am running it through QGIS3. When I
> run it for the first time after opening it in QGIS3, the application's
> window pops up smoothly. However, when I close the window and run the
> script, QGIS3 readily quits.  That may be something related to the event
> loop, but I'm unsure and don't know how to stop the QGIS3 shutdown for the
> subsequent runs.  Any hint on how to fix this issue will be very
> appreciated.
> import sys
>                           Qt)
>                               QWidget,
>                               QPushButton,
>                               QMainWindow)
>     def _init_(self):
>         super()._init_()
> window.show()
> app.exec()
> *Julierme G Pinheiro*
> *SDI Expert & Geoprocessing Specialist*
> Phone: +55 61 99994-3569
> Website: GIS
> <https://www.udemy.com/course/qgis-server-para-iniciantes-instalacao-e-configuracao/>
> QGIS-User mailing listQGIS-User at lists.osgeo.org
Website: GIS
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230816/13f66890/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230816/13f66890/attachment.png>
More information about the QGIS-User mailing list
