[Qgis-user] QGIS3 quits after PyQt Script 2 run
Ludwig Kniprath
ludwig at kni-online.de
Thu Aug 17 00:37:00 PDT 2023
Hi Julierme,
that's another and not a new problem, the button-widget and setFixedSize
did not work before and even do not work in standalone-python outside QGis.
The reason is quite simple, we overlooked it before: double-underscores
for the __init__-functions.
Here the running code, which does what You want (commented lines for
QGis-usage, uncomment for standalone):
import sys
from PyQt5.QtCore import (QSize, Qt)
from PyQt5.QtWidgets import (QApplication,
QWidget,
QPushButton,
QMainWindow)
class MainWindow(QMainWindow):
def __init__(self):
super().__init__()
self.setWindowTitle("My App")
button = QPushButton("Press Me!")
self.setCentralWidget(button)
self.setFixedSize(QSize(400, 300))
#app = QApplication(sys.argv)
window = MainWindow()
window.show()
#app.exec()
hth
Ludwig
Am 17.08.23 um 04:14 schrieb 1520 gis:
> Hi Ludwig,
> Thank you very much for your reply. You're right, QGIS stopped
> crashing, but now the button widget is not being carried out by the
> application window and neither the methods are working properly like
> the self.setFixedSize(QSize(400,300)). I am sending a window
> screenshot in attachment.
> I appreciated your time and help.
> Kind regards
> Julierme
> On Wed, Aug 16, 2023 at 4:07 PM Ludwig Kniprath via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
> Hi Julierme,
> I think Your problem is, that You try to create a new application
> with "app = QApplication(sys.argv)" inside a running QGis, which
> already is a running Qt-application.
> Simplified code should perform without crash:
> import sys
> from PyQt5.QtCore import (QSize,Qt)
> from PyQt5.QtWidgets import (QApplication, QWidget, QPushButton,
> QMainWindow)
> def _init_(self):
> super()._init_()
> window.show()
> hth
> Ludwig
> Am 16.08.23 um 19:15 schrieb 1520 gis via QGIS-User:
>> Hi all,
>> I wrote the PyQt script below and I am running it through QGIS3.
>> When I run it for the first time after opening it in QGIS3, the
>> application's window pops up smoothly. However, when I close the
>> window and run the script, QGIS3 readily quits. That may be
>> something related to the event loop, but I'm unsure and don't
>> know how to stop the QGIS3 shutdown for the subsequent runs. Any
>> hint on how to fix this issue will be very appreciated.
>> import sys
>> Qt)
>> QWidget,
>> QPushButton,
>> QMainWindow)
>> def _init_(self):
>> super()._init_()
>> window.show()
>> app.exec()
>> *Julierme G Pinheiro*
>> *SDI Expert & Geoprocessing Specialist*
>> Phone: +55 61 99994-3569
>> Website: GIS
>> <https://www.udemy.com/course/qgis-server-para-iniciantes-instalacao-e-configuracao/>
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Website: GIS
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230817/baf79367/attachment.htm>
More information about the QGIS-User
