[Qgis-user] IDW Interpolation not working, help!?
Alexandre Neto senhor.neto at gmail.com
Fri Dec 8 09:12:25 PST 2023
Have you tried with a clean profile?
Have you tried with a different dataset?
Best regards,
Alexandre Neto
A sexta, 8/12/2023, 14:18, Jos Thio via QGIS-User <qgis-user at lists.osgeo.org>
escreveu:
> Hi All,
> I have been attempting to interpolate some data, but have been unable to
> make any progress. The function is not working - I have already uninstalled
> two new versions of Q to see if it works before returning to Firenze.
> However, still no luck.
> I hit 'Run' - the meter shoots to 99% - before dropping to 0% and hanging.
> Can anyone suggest a fix or know what is going on?
>    which QGIS version ? - *3.28.13*
>    what are you expecting to get? - *an interpolated surface made from
>    z-value in points shapefile cut to the extent of a polygon*
>    if applicable, what have you tried and the result you got? -* No
>    results, simply left hanging on 0% for over 40 minutes before quitting
>    application*
> Jos Thio
> Geothermal Geologist
> *GeoScience Limited *
> *Oilfield Geomechanics*
> <https://www.geoscience.co.uk/oilfieldgeomechanics>*-   **Geothermal
> Engineering*  <https://www.geoscience.co.uk/geothermal> *-  **Ground
> Source Heat Pumps* <https://www.geoscience.co.uk/gshp>
> *tel:* +44 (0) 1326 211070 | *web:* www.geoscience.co.uk
> *_____________________________________________________________*
> Falmouth Business Park | Bickland Water Rd | Falmouth | Cornwall | TR11
> 4SZ | UK
> *Registered in England No:* 1930745
> *IMPORTANT NOTICE*: This email is confidential, may be legally
> privileged, and is for the intended recipient only. Access, disclosure,
> copying, distribution or reliance on any of it by anyone else is prohibited
> and may be a criminal offence. If you have received this email in error
> please inform the sender and delete it from your mailbox or any other
> storage mechanism. Any communication of a personal nature in this message
> is not made by or on behalf of any GeoScience Group company. Please note
> that the sender’s email address and all other GeoScience Group email
> addresses are not valid addresses for the service of legal proceedings.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231208/499d5082/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231208/499d5082/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231208/499d5082/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231208/499d5082/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231208/499d5082/attachment-0007.png>
More information about the QGIS-User mailing list
