[Qgis-user] Problem with Python/Qgis
Ludwig Kniprath ludwig at kni-online.de
Tue Dec 12 09:22:27 PST 2023
Hi Gael,
I'm using QGis on Linux Mint, an Ubuntu fork, with no problems, so just
some notes.
- Did you follow
https://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu?
- Did you run "sudo apt update" before "sudo apt install"?
- There seems to be an older installation, You could try "sudo apt-get
purge qgis qgis-plugin-grass python3-qgis qgis-providers qgis-common"
before...
hth
Ludwig
Am 12.12.23 um 16:57 schrieb Gael Kermarrec via QGIS-User:
> Dear members,
> I am trying to install Qgis from Ubuntu 20.04 but everytime I make
> sudo apt install qgis qgis-plugin-grass I become the following:
> The following packages contain unsatisfied dependencies:
> qgis: Depends on python3-qgis (= 1:3.22.16+32focal) but
> 1:3.26.3+32focal-ubuntugis needs to be installed
> Depends on qgis-providers (= 1:3.22.16+32focal) but
> Depends on qgis-common (= 1:3.22.16+32focal) but
> qgis-plugin-grass: Depends on qgis-plugin-grass-common (=
> 1:3.22.16+32focal) but 1:3.26.3+32focal-ubuntugis needs to be installed
> Depends on grass782
> E: Unable to correct problems, defective packages are in "keep in the
> current state" mode.
> I have no idea what I should do to make it works. Maybe somebody had
> the same problem, I would be grateful to get some support as I would
> like to work with QGis.
> Thanks,
> gael.
More information about the QGIS-User mailing list
