[Qgis-user] use Binary (Blob) in writeAsVectorFormat
chris hermansen clhermansen at gmail.com
Fri Feb 3 14:13:45 PST 2023
Hugh and list;
On Fri, Feb 3, 2023 at 11:41 AM Hugh Kelley via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> to follow up as I continue to work on this,
> I mistakenly understood the attribute type "binary" as a Boolean, but I
> think it's in fact an arbitrary value stored as binary. That is to say, not
> necessarily True/False or 0/1 but a series of 0/1's storing a value.
> If I can save it to the shapefile that would be great but I'm going to
> work on filtering those attributes out of what's saved as that's an
> acceptable solution too I think.
> On Fri, Feb 3, 2023 at 2:24 PM Hugh Kelley <hghklly at gmail.com> wrote:
>> Hi,
>> I'm attempting to use pyqgis to export a few things to shapefile.
>> the code below is working well except that a few of the attributes are
>> incompatible with shapefiles (amazing) lack of a binary datatype.
>> ```py
>> pathToFile = "C:/Users/hkelley/Downloads/test_exports/
>> layers = QgsProject.instance().mapLayers()
>> for layer_id, layer in layers.items():
>>     print(layer.name())
>>     QgsVectorFileWriter.writeAsVectorFormat( layer,  pathToFile+
>> layer.name() + ".shp", "utf-8", layer.crs(), driverName="ESRI Shapefile"
>> I see in the manual export options that I can check a box telling the
>> export process to use "Use Binary (BLOB)". Image linked below for clarity
>> [0]
>> I haven't yet figured out how to pass that option to writeAsVectorFormat.
>> any suggestions?
>> Iv'e had a pretty thorough look through the docs for writeAsVctorFormat,
>> is the solution related to
>> QgsVectorFileWriter.BoolOption(QgsVectorFileWriter.BoolOption)?
Have you looked at this https://en.wikipedia.org/wiki/.dbf to understand
how attributes are stored in .dbf files?
In particular there you will see this comment:
*All field data is ASCII. Depending on the field's type, the application
imposes further restrictions: *
Does this help?
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230203/6aaf274e/attachment.htm>
More information about the QGIS-User mailing list
