[Qgis-user] WFS - Env variable QGIS_SERVER_API_WFS3_MAX_LIMIT not working
Alessandro Pasotti apasotti at gmail.com
Tue Feb 14 03:15:22 PST 2023
that variable is for OAPIF (AKA WFS3) only, it does not apply to plain old WFS.
There is a bug in the manual, I'll fix that.
It should read:
Maximum value for limit in a OAPIF features request.
On Tue, Feb 14, 2023 at 12:11 PM Tommaso via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Hello,
> I'm trying to limit the max number of features returned by my Qgis Server
> using the environment variable QGIS_SERVER_API_WFS3_MAX_LIMIT
> QGIS_SERVER_API_WFS3_MAX_LIMIT=1000
> The server seems to consider the variable and write to the log file
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT /
> '/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features
> request, defaults to 10000): '1000' (read from ENVIRONMENT_VARIABLE)
> The server should return max 1000 features, but it still returns all
> features. The limit is ignored. How can I debug the problem?
> My WFS request:
> http://XXXXXXXXX/qgisserver?SERVICE=WFS&VERSION=1.0.0&MAP=/etc/qgisserver/project.qgs&service=WFS&request=GetFeature&typename=Gemeinde
> Version: Qgis Server 3.28.0 (camptocamp docker image)
> The begin of the log file:
> 10:41:20 INFO Server[90]: QGIS Server Starting : 3.28.0-Firenze
> (ed3ad0430f)
> 10:41:20 INFO Server[90]: QGIS Server Settings:
> 10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (Override the default
> path for user configuration): '' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_PARALLEL_RENDERING /
> '/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
> getMap request): 'false' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_MAX_THREADS / '/qgis/max_threads'
> (Number of threads to use when parallel rendering is activated): '-1' (read
> from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_LEVEL / '' (Log level): '0'
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_FILE / '' (Log file):
> '/etc/qgisserver/qgisserver.log' (read from ENVIRONMENT_VARIABLE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_STDERR / ''
> (Activate/Deactivate logging to stderr): '1' (read from
> 10:41:20 INFO Server[90]:   - QGIS_PROJECT_FILE / '' (QGIS project file):
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_IGNORE_BAD_LAYERS / '' (Ignore
> bad layers): 'false' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_DIRECTORY /
> '/cache/directory' (Specify the cache directory):
> '/tmp/profiles/default/cache' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size'
> (Specify the cache size): '268435456' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
> '/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
> '/locale/userLocale' (Override system locale): '' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_HEIGHT /
> '/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of
> this and the project configuration is used.): '-1' (read from
> DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_WIDTH /
> '/qgis/max_wms_width' (Maximum width for a WMS request. The most
> conservative between this and the project one is used): '-1' (read from
> DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY /
> '/qgis/server_api_resources_directory' (Base directory where HTML templates
> and static assets (e.g. images, js and css files) are searched for)
> : '/usr/local/share/qgis/resources/server/api' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_TRUST_LAYER_METADATA / '' (Trust
> layer metadata): 'false' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_FORCE_READONLY_LAYERS / '' (Force
> to open layers in read-only mode): 'false' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_DISABLE_GETPRINT / '' (Don't load
> layouts): 'false' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LANDING_PAGE_PROJECTS_DIRECTORIES
> / '/qgis/server_projects_directories' (Directories used by the landing page
> service to find .qgs and .qgz projects): '' (read from DEFA
> ULT_VALUE)
> QGIS_SERVER_LANDING_PAGE_PROJECTS_PG_CONNECTIONS /
> '/qgis/server_projects_pg_connections' (PostgreSQL connection strings used
> by the landing page service to find projects): '' (read
>   from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_PROFILE /
> '/qgis/server_log_profile' (Add detailed profile information to the logs,
> only effective when QGIS_SERVER_LOG_LEVEL=0): 'false' (read from
> DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_WMTS_SERVICE_URL /
> '/qgis/server_wmts_service_url' (The default WMTS service URL): '' (read
> from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (): '' (read from
> DEFAULT_VALUE)
> DEFAULT_VALUE)
> DEFAULT_VALUE)
> DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_LANDING_PAGE_PREFIX /
> '/qgis/server_landing_page_base_url_prefix' (Landing page base URL path
> prefix): '' (read from DEFAULT_VALUE)
> 10:41:20 INFO Server[90]:   - QGIS_SERVER_PROJECT_CACHE_CHECK_INTERVAL /
> '/qgis/server_project_cache_check_interval' (The default project cache
> check interval): '0' (read from DEFAULT_VALUE)
> Thank you and best regards,
> Tommaso
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-User mailing list
