[Qgis-user] WFS - Env variable QGIS_SERVER_API_WFS3_MAX_LIMIT not working
Tommaso tommasodb at googlemail.com
Tue Feb 14 03:11:38 PST 2023
Hello,
I'm trying to limit the max number of features returned by my Qgis Server
using the environment variable QGIS_SERVER_API_WFS3_MAX_LIMIT
QGIS_SERVER_API_WFS3_MAX_LIMIT=1000
The server seems to consider the variable and write to the log file
10:41:20 INFO Server[90]:   - QGIS_SERVER_API_WFS3_MAX_LIMIT /
'/qgis/server_api_wfs3_max_limit' (Maximum value for "limit" in a features
request, defaults to 10000): '1000' (read from ENVIRONMENT_VARIABLE)
The server should return max 1000 features, but it still returns all
features. The limit is ignored. How can I debug the problem?
My WFS request:
http://XXXXXXXXX/qgisserver?SERVICE=WFS&VERSION=1.0.0&MAP=/etc/qgisserver/project.qgs&service=WFS&request=GetFeature&typename=Gemeinde
Version: Qgis Server 3.28.0 (camptocamp docker image)
The begin of the log file:
10:41:20 INFO Server[90]: QGIS Server Starting : 3.28.0-Firenze
(ed3ad0430f)
10:41:20 INFO Server[90]: QGIS Server Settings:
10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (Override the default
path for user configuration): '' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_PARALLEL_RENDERING /
'/qgis/parallel_rendering' (Activate/Deactivate parallel rendering for WMS
getMap request): 'false' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_MAX_THREADS / '/qgis/max_threads'
(Number of threads to use when parallel rendering is activated): '-1' (read
from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_LEVEL / '' (Log level): '0'
10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_FILE / '' (Log file):
'/etc/qgisserver/qgisserver.log' (read from ENVIRONMENT_VARIABLE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_STDERR / ''
(Activate/Deactivate logging to stderr): '1' (read from
10:41:20 INFO Server[90]:   - QGIS_PROJECT_FILE / '' (QGIS project file):
10:41:20 INFO Server[90]:   - QGIS_SERVER_IGNORE_BAD_LAYERS / '' (Ignore
bad layers): 'false' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_DIRECTORY /
'/cache/directory' (Specify the cache directory):
'/tmp/profiles/default/cache' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_CACHE_SIZE / '/cache/size'
(Specify the cache size): '268435456' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_SHOW_GROUP_SEPARATOR /
'/locale/showGroupSeparator' (Show group (thousands) separator): 'false'
10:41:20 INFO Server[90]:   - QGIS_SERVER_OVERRIDE_SYSTEM_LOCALE /
'/locale/userLocale' (Override system locale): '' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_HEIGHT /
'/qgis/max_wms_height' (Maximum height for a WMS request. The lower one of
this and the project configuration is used.): '-1' (read from
DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_WMS_MAX_WIDTH /
'/qgis/max_wms_width' (Maximum width for a WMS request. The most
conservative between this and the project one is used): '-1' (read from
DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_API_RESOURCES_DIRECTORY /
'/qgis/server_api_resources_directory' (Base directory where HTML templates
and static assets (e.g. images, js and css files) are searched for)
: '/usr/local/share/qgis/resources/server/api' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_TRUST_LAYER_METADATA / '' (Trust
layer metadata): 'false' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_FORCE_READONLY_LAYERS / '' (Force
to open layers in read-only mode): 'false' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_DISABLE_GETPRINT / '' (Don't load
layouts): 'false' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_LANDING_PAGE_PROJECTS_DIRECTORIES
/ '/qgis/server_projects_directories' (Directories used by the landing page
service to find .qgs and .qgz projects): '' (read from DEFA
ULT_VALUE)
QGIS_SERVER_LANDING_PAGE_PROJECTS_PG_CONNECTIONS /
'/qgis/server_projects_pg_connections' (PostgreSQL connection strings used
by the landing page service to find projects): '' (read
  from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_LOG_PROFILE /
'/qgis/server_log_profile' (Add detailed profile information to the logs,
only effective when QGIS_SERVER_LOG_LEVEL=0): 'false' (read from
DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_WMTS_SERVICE_URL /
'/qgis/server_wmts_service_url' (The default WMTS service URL): '' (read
from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_OPTIONS_PATH / '' (): '' (read from
DEFAULT_VALUE)
DEFAULT_VALUE)
DEFAULT_VALUE)
DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_LANDING_PAGE_PREFIX /
'/qgis/server_landing_page_base_url_prefix' (Landing page base URL path
prefix): '' (read from DEFAULT_VALUE)
10:41:20 INFO Server[90]:   - QGIS_SERVER_PROJECT_CACHE_CHECK_INTERVAL /
'/qgis/server_project_cache_check_interval' (The default project cache
check interval): '0' (read from DEFAULT_VALUE)
Thank you and best regards,
Tommaso
More information about the QGIS-User mailing list
