[Qgis-user] LIDAR
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Feb 16 04:40:03 PST 2023
We are adding Virtual Point Cloud format and will be ready in QGIS later
this year (June 2023):
https://github.com/PDAL/wrench#virtual-point-clouds-vpc
This should address your issue. But meanwhile you can combine all your
files into a single COPC file.
Kind regards
Saber
On Wed, 15 Feb 2023 at 02:56, Nicolas Cadieux via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> On regular raster and vector layers, you can also right click on the layer
> in the layer manager and cut and paste the style. I figure it must be the
> same with LiDAR. CloudCompare is also very good for working with LiDAR. I
> have been working with files with over 250 millions points lately with no
> trouble. Same thing in QGIS. So far so good!
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 14 févr. 2023 à 09:05, Kirk Schmidt via QGIS-User <
> qgis-user at lists.osgeo.org> a écrit :
> Hi Allan:
> One way is to combine the files into a super file which may not be an
> option due to size. The other would be to find the total range of z values
> in your project area and set the min and max symbology for the Z
> attribute. while using the attributes by ramp option. You can save the
> style and use it for the remaining point clouds.
> Kirk Schmidt
> On 2/13/2023 11:49 PM, Allan Younger via QGIS-User wrote:
> Hi everyone,
> I have multiple Lidar downloaded las files, on opening find each has its
> individual range of levels.
> How can I shade uniform levels?
> 200m plus points in several of blocks.
> Chrs
> AY
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Kirk Schmidt, MScF, BScF, RPF
> General Manager
> Nortek Resource Solutions Inc.
> 26 Church Road
> Sutherlands River, NS
> B0K 1W0
> Tel (902) 922.3607
> Email: kirk at nortekresources.com
> Web: www.nortekresources.com
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230216/c16ed4ca/attachment.htm>
More information about the QGIS-User
