[Qgis-user] Two LAZ file possible issues iwth some new data we received to processs
Even Rouault even.rouault at spatialys.com
Thu Feb 16 17:11:16 PST 2023
Le 16/02/2023 à 23:41, Mike Stanton via QGIS-User a écrit :
> I have LAZ files  for a square mile of the local area where my office
> is and when it is loaded under QGIS I hit two problems. It is a bit
> over 2000 files and I seem to have hit a capacity limit where it stops
> processing the images at about 200 files.  The message being output
> for the files is “Failed to Calculate Statistics of the Point Cloud of
> XXXXXXXXXXXX.LAZ”.   Breaking it into smaller pieces gets the project
> around the scale limits of the product because the doing only the
> rejected files gets me more files processed, but it is not convenient
> considering I expect to be processing a lot more of these files.
> The other problem is that QGIS tells me I don’t have a CRS for the
> images and the image has a field that says “No CRS Found” in the log
> file and what I have is data in the header that says “COMPD_CS
> [“Projected”, PROJCS “UTM 15N”, GEOGCS [WGS84 …. “  but the strings
> have unpaired square brackets round the relevant text. Is this what
> may be causing the error to occur?
Can you paste the exact CRS WKT string ? Though I doubt it is related
with the 200 file limit issue
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230217/2e49d56f/attachment.htm>
More information about the QGIS-User mailing list
