[Qgis-user] [FILTER] How to filter a layer by minimum attribute value
Dirk.Pispers at STADT-KOELN.DE Dirk.Pispers at STADT-KOELN.DE
Sat Feb 18 02:58:37 PST 2023
you can use the layer filter for this. The exact filter expression depends on the data source you use, because you have to use the SQL-Syntax of your data source.
To filter a layer with data source in an geopackage you can use:
"HubDist" = (select min(HubDist) from hubs)
min() is the minimum function in SQLite (geopackage uses SQLite-Syntax), hubs is the name of the layer.
In PostgreSQL the function is also called min(). In other data source it may be another function (if there is one).
Regards Dirk
Von: QGIS-User [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Igor Oliveira Ribeiro via QGIS-User
Gesendet: Freitag, 17. Februar 2023 20:25
An: qgis-user <qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] [FILTER] How to filter a layer by minimum attribute value
how can I filter layer by the minimum value of the field "HubDist" in the attribute table?
See my attribute table below. As result, I expect only one attribute being showed in my map related to "HubDist" equal 111.3546... (the value in the first line).
[image.png]
Thanks for your help.
See our last paper: <https://doi.org/10.1016/j.envpol.2020.114029>
Impact of biomass burning on a metropolitan area in the Amazon during the 2015 El Niño: The enhancement of carbon monoxide and levoglucosan concentrations.<https://doi.org/10.1016/j.envpol.2020.114029>
[https://lh5.googleusercontent.com/-bliIGlTBH64UHBAAns8Ubhxgih0cgNVZjNAWPkBZSkYIa-o9idb3Km_x571oZ3NL0nZVMvFmclRedyzJDfv00BMdZPjcKg4zD1y1yGGErKoPszFJuTRjvN_0fmLsa4Ah_2YTtxJ]
Post-Doc on Regional Climate Change, Vulnerability, Impacts and Adaptation - Cuomo Foundation/UEA
+55 92 98103 7136 | skype: igorflorestal
Universidade do Estado do Amazonas | Instituto Nacional de Pesquisas da Amazônia
Visite: www.geoescrita.com.br<http://www.geoescrita.com.br>
[https://lh4.googleusercontent.com/2py0KXy5JccNXFC-38-2TT9wnYCQAXMRBlM5H0eOS83jy2Sz-PUr9_1C57srnad478ma9o9_fAYHjUhFN7Hza3OOCSiFHFpboznBl1PpVLavbfnjGYoU1usFc0W8j9pS4VzAKwCV]<https://www.linkedin.com/in/igoroliveiraribeiro/>[https://lh4.googleusercontent.com/-FUMJ4HbrYAwwTKB49CF6r39wVYnoWf1AD9ZLKvD6Z1Cu1yqyo8NRk-InWHOa34J87OHDcJcCstkC_khG2_jCc6qDGop64cV2F0OL-IZ1S3Jgf9SfxVF08U9xfx47ov24InhjsqE]<https://www.instagram.com/geoescrita/>[https://lh6.googleusercontent.com/ert1Bk_3idA2Vb4MK8Hd3B1p2vdcL52JrOmNjaGhhbS7caCNQiZwRKKX55B9pB7-3j2nPFttXJezhSxrHQeBpnEnpeD_CRjzBQgPo5hG5C68qhY1wRFMu0PDv9LbQ8iY8-K4bwIk]<https://www.researchgate.net/profile/Igor_Oliveira_Ribeiro>[https://lh6.googleusercontent.com/z9emf1sj2DW-tYYJZ6Qkd3RxvB23DjQdH7bLcTDIv9zyi-XnZRAroZBc8OPJqQkDIvZJBpd7GCa-2ClAT2gT3ubJ4yZj1BA0-T8hGgBboms-kjpowUuhBQO4z4EcWDwF9w25FGiy]<http://lattes.cnpq.br/3909691804095045>[https://lh4.googleusercontent.com/fOmYAxdij-Q_UFG3dFFnhy_zegLQSPZcgxSE-l8u9XuSz6LvnUGItsmoPZL_GCcfoYF2yl9dqYGs3842AcozPLqY103OWAe1x-js_lNLXym1Wcde7j4r19_vICiJXP5xaE_-KPIL]<https://orcid.org/0000-0002-3529-0525>[https://lh3.googleusercontent.com/H041znsV0LChyhfdBIDwXHwIh5BUG2TCmQYBSI1d4eF1NX80_T79MtdQqif3DHpBIDgzvXhuXDLc0l77eylJCPuW7jbalTIbVqBg-dm8S-JHOxZh458R0UX8SsJINhcqw7nG7_Pw]<https://www.geoescrita.com.br/>
Think globally, act locally!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230218/7831449a/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230218/7831449a/attachment-0001.png>
More information about the QGIS-User mailing list
