[Qgis-user] Two LAZ file possible issues iwth some new data we received to processs
Even Rouault even.rouault at spatialys.com
Mon Feb 20 09:57:12 PST 2023
To report to https://github.com/qgis/QGIS/issues
Le 20/02/2023 à 18:48, Mike Stanton via QGIS-User a écrit :
> Hi Nicolas, thank you for the well researched and detailed answer.  I
> was running on the latest build and it had a the new feature for Cloud
> Optimization COPC.  That feature doubled the number of open files for
> the process and I dropped back to 3.22 to get my processing done. It
> appears that during the indexing process  of 3.28 the COPC files are
> left open even after moving on to another LAZ file. The 3.22 level did
> not create the COPC files and everything worked out for the images.
> *From:* Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> *Sent:* Friday, February 17, 2023 7:20 AM
> *To:* Mike Stanton <mfstanton at geospan.com>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Two LAZ file possible issues iwth some new
> Hi,
> I did run into this layer number limite in the past.  If you check the
> user list or if you Google “QGIS, maximum amount of layers… “ you will
> find multiple post. The issue, at the time was caused by limites in
> the OS.  (Windows 7 at the time), OSX had and easy work around.  Same
> thing for the various flavours of  Linux.
> At the time, I either combined files when using QGIS or opened them in
> Saga that did not have this problem. I believe this was  because Saga,
> at least back then, loaded all the file into memory and did not keep a
> handle on the files once is was open.
> This is the type of thing that got me into learning Python so that I
> could create loops and speed up operations on LiDAR data.
> It’s normal (or at least expected)  for large batches of file to have
> bugs in them like missing crs in headers.  File transfers can be
> difficult to handle.  Talk with the provider to see if they have the
> same issue.  If you know a bit of Python, I could send you a script
> that reads the LiDAR header directly.
> LasPy is a good little library for this
> https://laspy.readthedocs.io/en/latest/intro.html#header
> You could find tools in WhiteboxTools also.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>     Le 16 févr. 2023 à 17:50, Mike Stanton via QGIS-User
>     <qgis-user at lists.osgeo.org> a écrit :
>     I have LAZ files  for a square mile of the local area where my
>     office is and when it is loaded under QGIS I hit two problems. It
>     is a bit over 2000 files and I seem to have hit a capacity limit
>     where it stops processing the images at about 200 files.  The
>     message being output for the files is “Failed to Calculate
>     Statistics of the Point Cloud of XXXXXXXXXXXX.LAZ”.   Breaking it
>     into smaller pieces gets the project around the scale limits of
>     the product because the doing only the rejected files gets me more
>     files processed, but it is not convenient considering I expect to
>     be processing a lot more of these files.
>     The other problem is that QGIS tells me I don’t have a CRS for the
>     images and the image has a field that says “No CRS Found” in the
>     log file and what I have is data in the header that says “COMPD_CS
>     [“Projected”, PROJCS “UTM 15N”, GEOGCS [WGS84 …. “  but the
>     strings have unpaired square brackets round the relevant text. Is
>     this what may be causing the error to occur?
>     _______________________________________________
>     QGIS-User mailing list
>     QGIS-User at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230220/619e231e/attachment-0001.htm>
More information about the QGIS-User mailing list
