[Qgis-user] QGIS (OGR) updating ESRI file geodatabases
chris hermansen clhermansen at gmail.com
Tue Feb 28 09:26:04 PST 2023
Thanks Randy,
If I understand Even Roualt's earlier reply it's only the FGDB version 10
and newer that can be edited.  I was really hoping for the version 9 ones...
On Tue, Feb 28, 2023 at 8:58 AM Randal Hale via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hey Chris - So I've done two things in this area (I'm currently on fedora
> on one machine and ubuntu on a second).
> Flatpak will let you edit FGDBs and has updated gdal (i believe officially
> sanctioned through QGIS)
> Currently I'm working with this:
> https://github.com/conda-forge/qgis-feedstock and it's pretty smooth (you
> just have to install conda) and can edit FGDB.
> Good luck,
> Randy
> On 2/28/23 10:38, chris hermansen via QGIS-User wrote:
> Thanks Even, I appreciate the clarification though I'm sobbing quietly
> because I was hoping for ArcGIS 9 support.
> On Tue, Feb 28, 2023 at 4:24 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> However today I stumbled upon this:
>> https://gdal.org/drivers/vector/openfilegdb.html
>> which clearly states:
>> The OpenFileGDB driver provides read, write and update access to vector
>>> layers of File Geodatabases (.gdb directories) created by ArcGIS 9 and
>>> above.
>> That was misleading. I've just corrected it. Write support is only for
>> ArcGIS 10.x geodatabases
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> -- https://www.northrivergeographic.com
> (423) 653-3611 rjhale at northrivergeographic.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230228/49027183/attachment.htm>
More information about the QGIS-User mailing list
