[Qgis-user] QGIS (OGR) updating ESRI file geodatabases
Randal Hale rjhale at northrivergeographic.com
Tue Feb 28 08:57:47 PST 2023
Hey Chris - So I've done two things in this area (I'm currently on
fedora on one machine and ubuntu on a second).
Flatpak will let you edit FGDBs and has updated gdal (i believe
officially sanctioned through QGIS)
Currently I'm working with this:
https://github.com/conda-forge/qgis-feedstock and it's pretty smooth
(you just have to install conda) and can edit FGDB.
Good luck,
Randy
On 2/28/23 10:38, chris hermansen via QGIS-User wrote:
> Thanks Even, I appreciate the clarification though I'm sobbing quietly
> because I was hoping for ArcGIS 9 support.
> On Tue, Feb 28, 2023 at 4:24 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>>     However today I stumbled upon this:
>>     https://gdal.org/drivers/vector/openfilegdb.html
>>     which clearly states:
>>         The OpenFileGDB driver provides read, write and update access
>>         to vector layers of File Geodatabases (.gdb directories)
>>         created by ArcGIS 9 and above.
>     That was misleading. I've just corrected it. Write support is only
>     for ArcGIS 10.x geodatabases
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
https://www.northrivergeographic.com
(423) 653-3611
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230228/cb9cde27/attachment-0001.htm>
More information about the QGIS-User mailing list
