[Qgis-user] QGIS behavior for DB table with single general geometry column vs table with multiple specific geometry columns
Johannes Echterhoff
echterhoff at interactive-instruments.de
Mon Jan 2 00:57:34 PST 2023
Even,
Thank you for the follow-up. It helps to complete the picture in this email thread.
For the use case, I am also looking for cases in which a) the table is empty (like at the start of editing) and b) the table only contains features with a subset of the specific geometry types that should be usable in general (like Point and LineString are already used, but Polygon is not – and thus no Polygon-Layer is shown). I know that this is a rather specific use case (in which GEOMETRY typed columns should only have values from a specific set of geometry types, and that the according layers should be shown by QGIS right away, even for an empty table with such a geometry column). I just wanted to ensure that I am not missing some hidden QGIS feature or plugin that can achieve this.
Best regards,
Johannes
Von: Even Rouault <even.rouault at spatialys.com>
Gesendet: Freitag, 30. Dezember 2022 16:30
An: Johannes Echterhoff <echterhoff at interactive-instruments.de>; qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] QGIS behavior for DB table with single general geometry column vs table with multiple specific geometry columns
Johannes,
The issue is exactly that you checked "Don't resolve type of unrestricted columns (GEOMETRY)". If you uncheck it, the content of GEOMETRY columns will be scanned and you'll get one layer per found geometry type.
Even
Le 28/11/2022 à 14:39, Johannes Echterhoff via Qgis-user a écrit :
Hi all,
This topic may have come up before, in which case I apologize up-front. I just want to make sure that I am not missing anything.
My question is about the behavior in QGIS for a database table, let's call it "ft_geometry", with a single, general geometry column (geometry type is GEOMETRY), compared to the behavior of a table "ft_multi" which has multiple columns with a specific geometry type (for example, one column with MULTIPOINT and one with MULTILINESTRING). When I connect to such a database - e.g., a PostgreSQL one - and open it in the project browser, then ft_geometry is not shown at all, while ft_multi is shown as many times as there are columns with specific geometry type.
QGIS allows adding ft_geometry manually, thereby choosing a specific geometry type for editing, via the Data Source Manager and via the DB Manager. I'll explain that using an example database schema and QGIS screenshots in more detail below, just for reference. However, what I am wondering is: Is it possible to somehow achieve, that, when opening the database in the project browser, ft_geometry is also shown with a list of specific geometry types (e.g., point and line)? Is there maybe a configuration option where one could set the desired specific geometry types, to be used in such a scenario, or a plugin? I've scanned the list of available plugins in QGIS 3.28.0, without success - but I may very well have missed something there. The background of why I'd like to have a certain list of specific geometry types is that in my use case, objects represented by tables like ft_geometry always have the same list of specific geometry types - and there can be many such tables in the database, which is why I am searching for a way to avoid manually adding such tables (each as many times as the specific geometry types that are needed).
Any help or guidance would be very appreciated.
Best regards,
Johannes
P.S.: Here is the database schema as well as QGIS screenshots
CREATE EXTENSION postgis;
CREATE TABLE ft_geometry (
_id bigserial NOT NULL PRIMARY KEY,
name text,
position geometry(GEOMETRY,25832)
CREATE TABLE ft_multi (
name text,
position_point geometry(MULTIPOINT,25832),
position_line geometry(MULTILINESTRING,25832),
position_polygon geometry(MULTIPOLYGON,25832)
CREATE INDEX idx_ft_geometry_position ON ft_geometry USING GIST (position);
CREATE INDEX idx_ft_multi_position_point ON ft_multi USING GIST (position_point);
CREATE INDEX idx_ft_multi_position_line ON ft_multi USING GIST (position_line);
CREATE INDEX idx_ft_multi_position_polygon ON ft_multi USING GIST (position_polygon);
My test project, in which I've connected to the "test_geometry" database; table ft_geometry is not shown in the project browser ("Also list tables with no geometry" is enabled in the connection settings, as is "Don't resolve type of unrestricted columns (GEOMETRY)"); table ft_multi is shown three times:
[cid:image001.png at 01D91E90.A18879A0]
One can add ft_geometry via the Data Source Manager, by manually selecting the spatial type:
[cid:image002.png at 01D91E90.A18879A0]
[cid:image003.png at 01D91E90.A18879A0]
Another way to add ft_geometry is via the DB Manager; here is the view of ft_geometry in the DB Manager:
[cid:image004.png at 01D91E90.A18879A0]
And here is the view in the DB Manager for ft_multi (just in case):
[cid:image005.png at 01D91E90.A18879A0]
By selecting ft_geometry in the DB Manager view of database test_geometry, then right-clicking, the dialog with the option to "Add Layer (Advanced)..." opens:
[cid:image006.png at 01D91E90.A18879A0]
There, one can choose the specific geometry type - as well as CRS (which should be chosen to match the one defined in the column geometry definition):
[cid:image007.png at 01D91E90.A18879A0]
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0007.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0008.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0009.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0010.png>
Type: image/png
Desc: image005.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0011.png>
Type: image/png
Desc: image006.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0012.png>
Type: image/png
Desc: image007.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/78702d0e/attachment-0013.png>
More information about the QGIS-User
