[Qgis-user] wrong interpretation of .prj-file
gisfisch at t-online.de
Mon Jan 2 03:00:30 PST 2023
Hello list,
first: best wishes for a peaceful 2023 to everyone!
I often have to process shapefiles that come with a prj file including the
Authority: ESRI 102328 statement (complete content of that file see
below).
This .prj is processed wrong by QGIS 3.28, because QGIS sets the false
easting to 2.500.000 (which has to be 500.000) and it interpretes the
projection as 7 Stellen = decimal places which is 6 Stellen in fact.
Can I change the way QGIS interpretes the .prj-File? It is annoying to
change the projection setting for every single shapefile I load in the
legend for each new shape delivery. In ESRI-Software, the .prj is being read
correct.
Here is the complete .prj which is being interpreted wrong:
PROJCS["ETRS_1989_UTM_Zone_32N_6Stellen",GEOGCS["GCS_ETRS_1989",DATUM["D_ETR
S_1989",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0
],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAM
ETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Ce
ntral_Meridian",9.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of
_Origin",0.0],UNIT["Meter",1.0],AUTHORITY["ESRI",102328]]
Mit freundlichen Grüßen,
Uwe Fischer
Ingenieurbüro Fischer
Esbecker Str. 8
31036 Eime
T. 05182/8325
T. 0172/8876934
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230102/65c9f9fe/attachment.htm>
More information about the QGIS-User
