[Qgis-user] change position of an object (line) in a defined XY direction
nikolas.geueke at gmx.net nikolas.geueke at gmx.net
Wed Jan 4 07:22:52 PST 2023
Hello Qgis users!
I am searching for a way to change the position of an object (line) in a
defined XY direction.
The EPSG I am working with is 4326 (Where also the data where generated)
Qgis Version: 3.18.3
Problem description:
Agricultural field data was mapped with RTK tractor steering system.
Unfortunately the used RTK Base station was not set up correctly.
I calculated a position shift of     -0.0000033419,-0.0000052
Now I am searching for a method/ plugin/ . what allows me to shift (at best)
all elements of a shape layer in this direction.
With the Baseknot processing tool (don't know if that's the correct term?!)
I am able to change the Knot Coordinates but just by calculating and
entering manually.
Maybe someone has a good tip for me how to do this?
Kind regards,
Nikolas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230104/d72cb9d8/attachment.htm>
More information about the QGIS-User mailing list
