[Qgis-user] Export to ESRI File Geodatabase
Nyall Dawson nyall.dawson at gmail.com
Tue Jan 17 15:53:36 PST 2023
On Wed, 18 Jan 2023 at 07:04, Even Rouault via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Randal,
> Support for the OpenFileGDB driver in the Save As dialog only dates back
> to a few days ago per https://github.com/qgis/QGIS/pull/51397 , so
> you'll have to wait for 3.28.3
Just to clarify -- the missing bit in 3.28 was that FileGeodatabase
wasn't showing in the layer right-click menus.
It should still be possible to export to GDB in 3.28 without that fix.
>From the browser panel, you can create a new empty Geodatabase by
right-clicking on a folder, and then drag and drop layers directly
into that GDB to import them!
Nyall
> What you must see with the driver being interminently available is that
> some of your installations might have the FileGDB driver (not
> OpenFileGDB) that relies on the ESRI closed source SDK.
> Even
> Le 17/01/2023 à 21:56, Randal Hale via QGIS-User a écrit :
> > I don't think this is just me - BUT - I wanted to check before filing
> > a bug report. This is all with QGIS 3.28.2 On Windows 10 and using
> > GDAL 3.6.1
> > I was checking on a problem and had used Network Installer to install
> > QGIS - I had File Geodatabase as a choice for Export (Right Click on
> > Layer -> Export As ->pick  ESRI File Geodatabase).
> > I installed QGIS using the Stand Alone installer (after removing QGIS
> > Network Install) and didn't have ESRI File Geodatabase as a choice on
> > export Features. This is confirmed by another user using the
> > standalone installer.
> > I removed QGIS and Reinstalled using the Network Installer and didn't
> > have ESRI File Geodatabase as a choice (but I did before).
> > So it seems like I'm missing something - I've been digging through
> > options and creating new profiles but I can't make the ERI File
> > Geodatabase consistently appear or disappear. Is there something else
> > I should try?
> > Randy
> http://www.spatialys.com
> My software is free, but my time generally not.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
