[Qgis-user] Export to ESRI File Geodatabase
    Randal Hale
    rjhale at northrivergeographic.com
    Tue Jan 17 13:07:01 PST 2023
Oh - That may have been. Well - I appreciate it. This has been bugging
me the whole weekend on why I couldn't make this work. Double happy I
didn't clog up the Bug Reporting Queue also.
Randy
On 1/17/23 16:03, Even Rouault wrote:
> Randal,
> Support for the OpenFileGDB driver in the Save As dialog only dates
> back to a few days ago per https://github.com/qgis/QGIS/pull/51397 ,
> so you'll have to wait for 3.28.3
> What you must see with the driver being interminently available is
> that some of your installations might have the FileGDB driver (not
> OpenFileGDB) that relies on the ESRI closed source SDK.
> Even
> Le 17/01/2023 à 21:56, Randal Hale via QGIS-User a écrit :
>> I don't think this is just me - BUT - I wanted to check before filing
>> a bug report. This is all with QGIS 3.28.2 On Windows 10 and using
>> GDAL 3.6.1
>> I was checking on a problem and had used Network Installer to install
>> QGIS - I had File Geodatabase as a choice for Export (Right Click on
>> Layer -> Export As ->pick  ESRI File Geodatabase).
>> I installed QGIS using the Stand Alone installer (after removing QGIS
>> Network Install) and didn't have ESRI File Geodatabase as a choice on
>> export Features. This is confirmed by another user using the
>> standalone installer.
>> I removed QGIS and Reinstalled using the Network Installer and didn't
>> have ESRI File Geodatabase as a choice (but I did before).
>> So it seems like I'm missing something - I've been digging through
>> options and creating new profiles but I can't make the ERI File
>> Geodatabase consistently appear or disappear. Is there something else
>> I should try?
>> Randy
https://www.northrivergeographic.com
(423) 653-3611
More information about the QGIS-User
