[Qgis-user] CSV layer, Time column null expressie to test for NULL/empty?
Richard Duivenvoorde rdmailings at duif.net
Wed Jan 18 09:43:46 PST 2023
Pff, ok found a solution:
"bezoek.begintijd" IS NULL
works
So if I want to test for empty strings, or NULL (like strings), AND real NULLS, I use now:
( "bezoek.begintijd" IS NULL   OR   "bezoek.begintijd"  in ('', ' ', 'NULL') )
Regards,
On 1/18/23 18:31, Richard Duivenvoorde via QGIS-User wrote:
> We have csv data, which is loaded as layer via the Delimited Text Layer provider.
> The data contains both a date and a time column, which we have to format as isodatetime using an QGIS Expression.
> BUT sometimes time column is empty/no value (in which case we have to format it as isoTIME only).
> So we have to check IF the time column is empty, then only format the Date, else use Date AND Time.
> My problem is that I fail to create an expression for the test IF the column (see screenshot) is empty.
> I thought to use (our column is called "bezoek.begintijd"):
> "bezoek.begintijd"  in ('', ' ', NULL)
> BUT this does NOT return True or False, but NULL !!
> But:
> ("bezoek.begintijd"  in ('', ' ', NULL)) = NULL
> does ALSO NOT resolve to True... (also NULL)
> When the record has no data (the csv holds no data for that record), it shows
> <time: >
> if it has data:
> <time: 09:42:00>
> Anybody an idea what test I can use to test if the time column (which is typed as Time) is empty/null/none?
> Thanks for any pointers.
> Regards,
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
