[Qgis-user] CSV layer, Time column null expressie to test for NULL/empty?
kirk kirk at nortekresources.com
Thu Jan 19 00:53:04 PST 2023
You can also useCASEWhen field is null then 123else 321endKirk SchmidtSent from my Galaxy
-------- Original message --------From: Richard Duivenvoorde via QGIS-User <qgis-user at lists.osgeo.org> Date: 2023-01-18  1:44 p.m.  (GMT-04:00) To: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] CSV layer,
  Time column null expressie to test for NULL/empty? Pff, ok found a solution:"bezoek.begintijd" IS NULLworksSo if I want to test for empty strings, or NULL (like strings), AND real NULLS, I use now:( "bezoek.begintijd" IS NULL   OR   "bezoek.begintijd"  in ('', ' ', 'NULL') )Regards,Richard DuivenvoordeOn 1/18/23 18:31, Richard Duivenvoorde via QGIS-User wrote:> We have csv data, which is loaded as layer via the Delimited Text Layer provider.> > The data contains both a date and a time column, which we have to format as isodatetime using an QGIS Expression.> > BUT sometimes time column is empty/no value (in which case we have to format it as isoTIME only).> > So we have to check IF the time column is empty, then only format the Date, else use Date AND Time.> > My problem is that I fail to create an expression for the test IF the column (see screenshot) is empty.> > I thought to use (our column is called "bezoek.begintijd"):> > "bezoek.begintijd"  in ('', ' ', NULL)> > BUT this does NOT return True or False, but NULL !!> > But:> > > ("bezoek.begintijd"  in ('', ' ', NULL)) = NULL> does ALSO NOT resolve to True... (also NULL)> > When the record has no data (the csv holds no data for that record), it shows> <time: >> if it has data:> <time: 09:42:00>> > Anybody an idea what test I can use to test if the time column (which is typed as Time) is empty/null/none?> > Thanks for any pointers.> > Regards,> > Richard Duivenvoorde> > _______________________________________________> QGIS-User mailing list> QGIS-User at lists.osgeo.org> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user_______________________________________________QGIS-User mailing listQGIS-User at lists.osgeo.orgList info: https://lists.osgeo.org/mailman/listinfo/qgis-userUnsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230119/d766664b/attachment.htm>
More information about the QGIS-User mailing list
