[Qgis-user] QGIS & GPS
Brent Wood
Brent.Wood at niwa.co.nz
Thu Jan 19 18:50:06 PST 2023
Gidday and Happy New Year from New Zealand!
I have spent too many hours on this already, sigh... Hopefully someone can help.
I normally use QGIS with USB GPS units on Linux and don't have driver issues, everything just works. But I now need to re-introduce myself to QGIS on Windows to set things up for other users, and it is proving very painful.
I'm using QGIS dev (3.29), 3.22 & v3.28 at present. Same issue on Windows with all of them.
I have historically used a Globalsat BR-355S4 USB GPS on Windows with no problems. Just install the Prolific USB-serial driver and everything works fine.
My recent Linux work has been using a G-Mouse (U-blox 7) chipset GPS which Linux typically mounts as /dev/ttyACM0 and QGIS is fine with that. Linux needs no additional drivers to be installed for this to work.
Now I'm trying to get this working on Windows... I can install the U-blox VCP (virtual com port) driver. The native driver Win10 finds & installs also seems to work, but not with QGIS. I can connect to the relevant com port with several GPS monitoring applications & see the NMEA sentences fine. QGIS lists the port OK, but fails to connect on auto or to the port directly. This is not uncommon with the U-Blox 7, but none of the fixes I have found online have worked for me.
I just bought another GPS, a new model Globalsat one, BU-353N5, a replacement for the BR-355S4. This is not sending the $GP sentences, just the $GN ones. My GPS monitoring applications work OK with this on Linux & Windows, but QGIS on both platforms lists the device to connect to, but is unable to connect & use the GPS data. I can't even log the data with QGIS as QGIS won't connect to the port in the first place.
My 3 questions:
How can I get a U-Blox7 chipset GPS (which is working fine on Windows with other applications) recognised by and working with QGIS?
How can I get a Globalsat BU-353N or other GPS that does not output $GPGGA or $GPRWC, but provides $GNGGA instead, etc working with QGIS?
Can anyone suggest an alternative cheap, generic USB GPS which simply and reliably works with QGIS on Windows?
Is this something that I should file a bug report for (it does seem to be a fragility in QGIS that is not present in other GPS software)? I'm happy to send a working USB GPS to any dev willing to look into this.
Thanks
Brent Wood
Principal Technician, Fisheries
NIWA
DDI: +64 (4) 3860529
[https://www.niwa.co.nz/static/niwa-2018-horizontal-180.png] <https://www.niwa.co.nz>
Brent Wood
Principal Technician - GIS and Spatial Data Management
Programme Leader - Environmental Information Delivery
+64-4-386-0529
National Institute of Water & Atmospheric Research Ltd (NIWA)
301 Evans Bay Parade Hataitai Wellington New Zealand
Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz> Facebook<https://www.facebook.com/nzniwa> LinkedIn<https://www.linkedin.com/company/niwa> Twitter<https://twitter.com/niwa_nz> Instagram<https://www.instagram.com/niwa_science>
To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230120/5a422b1f/attachment.htm>
More information about the QGIS-User
