[Qgis-user] QGIS & GPS
Stefan Giese (WhereGroup)
stefan.giese at wheregroup.com
Thu Jan 19 22:29:50 PST 2023
Hi Brent,
we solved this for one of our customers with the following steps:
* Installing U-Center on the windows computer:
https://www.u-blox.com/en/product/u-center
* in U-Center -> View -> Configuration view → NMEA (NMEA Protocol)
* change "Main Talker ID" to "1 – GP(GPS)"
* click on "SEND" and then on "POLL"
* now QGIS should directly communicate
hope this helps
Stefan
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Jetzt neu: Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 20.01.2023 um 03:50 schrieb Brent Wood via QGIS-User:
> Gidday and Happy New Year from New Zealand!
> I have spent too many hours on this already, sigh... Hopefully someone
> can help.
> I normally use QGIS with USB GPS units on Linux and don't have driver
> issues, everything just works. But I now need to re-introduce myself
> to QGIS on Windows to set things up for other users, and it is proving
> very painful.
> I'm using QGIS dev (3.29), 3.22 & v3.28 at present. Same issue on
> Windows with all of them.
> I have historically used a Globalsat BR-355S4 USB GPS on Windows with
> no problems. Just install the Prolific USB-serial driver and
> everything works fine.
> My recent Linux work has been using a G-Mouse (U-blox 7) chipset GPS
> which Linux typically mounts as /dev/ttyACM0 and QGIS is fine with
> that. Linux needs no additional drivers to be installed for this to work.
> Now I'm trying to get this working on Windows... I can install the
> U-blox VCP (virtual com port) driver. The native driver Win10 finds &
> installs also seems to work, but not with QGIS. I can connect to the
> relevant com port with several GPS monitoring applications & see the
> NMEA sentences fine. QGIS lists the port OK, but fails to connect on
> auto or to the port directly. This is not uncommon with the U-Blox 7,
> but none of the fixes I have found online have worked for me.
> I just bought anotherGPS, a new model Globalsat one, BU-353N5, a
> replacement for the BR-355S4. This is not sending the $GP sentences,
> just the $GN ones. My GPS monitoring applications work OK with this on
> Linux & Windows, but QGIS on both platforms lists the device to
> connect to, but is unable to connect & use the GPS data. I can't even
> log the data with QGIS as QGIS won't connect to the port in the first
> place.
> My 3 questions:
> How can I get a U-Blox7 chipset GPS (which is working fine on Windows
> with other applications) recognised by and working with QGIS?
> How can I get a Globalsat BU-353N or other GPS that does not output
> $GPGGA or $GPRWC, but provides $GNGGA instead, etc working with QGIS?
> Can anyone suggest an alternative cheap, generic USB GPS which simply
> and reliably works with QGIS on Windows?
> Is this something that I should file a bug report for (it does seem to
> be a fragility in QGIS that is not present in other GPS software)? I'm
> happy to send a working USB GPS to any dev willing to look into this.
> Thanks
> Brent Wood
> Principal Technician, Fisheries
> NIWA
> DDI: +64 (4) 3860529
> <https://www.niwa.co.nz> Brent Wood
> Principal Technician - GIS and Spatial Data Management
> Programme Leader - Environmental Information Delivery
> +64-4-386-0529
> National Institute of Water & Atmospheric Research Ltd (NIWA)
> 301 Evans Bay Parade Hataitai Wellington New Zealand
> *Connect with NIWA:* niwa.co.nz <https://www.niwa.co.nz> Facebook
> <https://www.facebook.com/nzniwa> LinkedIn
> <https://www.linkedin.com/company/niwa> Twitter
> <https://twitter.com/niwa_nz> Instagram
> <https://www.instagram.com/niwa_science>
> To ensure compliance with legal requirements and to maintain cyber
> security standards, NIWA's IT systems are subject to ongoing
> monitoring, activity logging and auditing. This monitoring and
> auditing service may be provided by third parties. Such third parties
> can access information transmitted to, processed by and stored on
> NIWA's IT systems
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230120/3f153a3c/attachment-0001.htm>
More information about the QGIS-User
