[Qgis-user] [Modeller] How to calculate area in the graphical modeler of QGIS
Alexandre Neto alexandre.neto at qcooperative.net
Mon Jan 30 06:50:53 PST 2023
Hello Igor,
Can you please explain what settings you have used in the field calculator
dialog. A screenshot would be helpful.
Alexandre Neto
User Support
www.qcooperative.net
[image: www.qcooperative.net] <http://www.qcooperative.net>
Igor Oliveira Ribeiro via QGIS-User <qgis-user at lists.osgeo.org> escreveu no
dia segunda, 30/01/2023 à(s) 13:14:
> Hi community,
> I need your help. I'm using QGIS 3.10.11 with Grass 7.8.4. I'm building a
> QGIS modeler and I want to calculate the area of an input polygon.
> So, my input polygon is a vector feature. I tried using a field calculator
> ($area) and Advanced Python Field Calculator (Field "Formula", I used
> "value = $geom.area() ).
> However, nothing is working. When I run the modeler, there is no error
> message. But, I'dont have the area calculated either.
> Thanks for your help.
> See our last paper:  <https://doi.org/10.1016/j.envpol.2020.114029>
> Impact of biomass burning on a metropolitan area in the Amazon during the
> 2015 El Niño: The enhancement of carbon monoxide and levoglucosan
> concentrations. <https://doi.org/10.1016/j.envpol.2020.114029>
> Post-Doc on Regional Climate Change, Vulnerability, Impacts and Adaptation
> - Cuomo Foundation/UEA
> +55 92 98103 7136 | skype: igorflorestal
> Universidade do Estado do Amazonas | Instituto Nacional de Pesquisas da
> Amazônia
> Visite: www.geoescrita.com.br
> <https://www.linkedin.com/in/igoroliveiraribeiro/>
> <https://www.instagram.com/geoescrita/>
> <https://www.researchgate.net/profile/Igor_Oliveira_Ribeiro>
> <http://lattes.cnpq.br/3909691804095045>
> <https://orcid.org/0000-0002-3529-0525> <https://www.geoescrita.com.br/>
> Think globally, act locally!
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Alexandre Neto
User Support
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230130/b7c40b73/attachment.htm>
More information about the QGIS-User mailing list
