[Qgis-user] [Modeller] How to calculate area in the graphical modeler of QGIS
Alexandre Neto alexandre.neto at qcooperative.net
Mon Jan 30 13:55:11 PST 2023
Hello Igor,
I don't have qgis here to test, but...
If I remember well, you need to  change the parameter type from value to
precalculated value.
If not, try adding single quotes around the expression.
Good luck,
Alexandre Neto
A segunda, 30/01/2023, 19:06, Igor Oliveira Ribeiro <
igorgeoinformacao at gmail.com> escreveu:
> Hey Alexandre, thanks for your reply.
> See below
> [image: image.png]
> On Mon, Jan 30, 2023 at 10:51 AM Alexandre Neto <
> alexandre.neto at qcooperative.net> wrote:
>> Hello Igor,
>> Can you please explain what settings you have used in the field
>> calculator dialog. A screenshot would be helpful.
>> Alexandre Neto
>> User Support
>> www.qcooperative.net
>> [image: www.qcooperative.net] <http://www.qcooperative.net>
>> Igor Oliveira Ribeiro via QGIS-User <qgis-user at lists.osgeo.org> escreveu
>> no dia segunda, 30/01/2023 à(s) 13:14:
>>> Hi community,
>>> I need your help. I'm using QGIS 3.10.11 with Grass 7.8.4. I'm building
>>> a QGIS modeler and I want to calculate the area of an input polygon.
>>> So, my input polygon is a vector feature. I tried using a field
>>> calculator ($area) and Advanced Python Field Calculator (Field "Formula", I
>>> used "value = $geom.area() ).
>>> However, nothing is working. When I run the modeler, there is no error
>>> message. But, I'dont have the area calculated either.
>>> Thanks for your help.
>>> See our last paper:  <https://doi.org/10.1016/j.envpol.2020.114029>
>>> Impact of biomass burning on a metropolitan area in the Amazon during
>>> the 2015 El Niño: The enhancement of carbon monoxide and levoglucosan
>>> concentrations. <https://doi.org/10.1016/j.envpol.2020.114029>
>>> Post-Doc on Regional Climate Change, Vulnerability, Impacts and
>>> Adaptation - Cuomo Foundation/UEA
>>> +55 92 98103 7136 | skype: igorflorestal
>>> Universidade do Estado do Amazonas | Instituto Nacional de Pesquisas da
>>> Amazônia
>>> Visite: www.geoescrita.com.br
>>> <https://www.linkedin.com/in/igoroliveiraribeiro/>
>>> <https://www.instagram.com/geoescrita/>
>>> <https://www.researchgate.net/profile/Igor_Oliveira_Ribeiro>
>>> <http://lattes.cnpq.br/3909691804095045>
>>> <https://orcid.org/0000-0002-3529-0525> <https://www.geoescrita.com.br/>
>>> Think globally, act locally!
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Alexandre Neto
>> User Support
> Impact of biomass burning on a metropolitan area in the Amazon during the
> Post-Doc on Regional Climate Change, Vulnerability, Impacts and Adaptation
> Amazônia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230130/2d7e7e44/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230130/2d7e7e44/attachment-0001.png>
More information about the QGIS-User mailing list
