[Qgis-user] Exporting maps out of QGIS into Adobe Pro to create layered pdf files
Richard Duivenvoorde rdmailings at duif.net
Wed Jul 12 13:23:58 PDT 2023
Hi Jamie,
There are several tastes of pdf...
One of them is 'GeoPDF', a layered pdf, which you can create if you create a layout first in QGIS and then export that to pdf.
For the options see: https://duif.net/pdfoptions.png
I've exported a simple map of two layers to: https://duif.net/nl.pdf
In most pdf viewers you can check/uncheck both layers, AND you can 'identify' objects there.
Can you check if that is what can be handled by your tools?
Regards,
On 7/12/23 22:10, Jamie Gould via QGIS-User wrote:
> Good afternoon,
> I am trying to export out my map in QGIS into Adobe Pro to create a layered PDF that I could toggle separate layers on and off.
> In the past I have done this through arcGIS, but I am currently at a company that uses geoSCOUT and you can't export a map in PDF form in geoSCOUT.  So, a former colleague told me that I can import shapefiles into QGIS and export the map to PDF that way - which works! However, when I bring the map into Adobe Pro, none of the separate layers show up and it's just a static PDF image.
> I just spent an hour with the Adobe help desk and the person I dealt with did all the things on the Adobe side and asked me to reach out to someone with QGIS to see if anyone has dealt with this before and how to get it working? Perhaps I have a setting off that I should have enabled, I'm really not sure.
> Any help is greatly appreciated. Thank you in advance,
> *Jamie**Gould*, *C. Tech*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
