[Qgis-user] Exporting maps out of QGIS into Adobe Pro to create layered pdf files
Jamie Gould jgould at longshore.ca
Wed Jul 12 13:49:22 PDT 2023
Thank you so much for the quick response.
I'm pretty new to QGIS.  In the first link you sent, are those PDF Export Options set in Adobe or in QGIS, and if so, where do I find the settings to see if this how things are currently configured?
I was able to open your map and turn the layers on and off successfully.
Cheers,
Jamie
From: Richard Duivenvoorde <rdmailings at duif.net>
Sent: Wednesday, July 12, 2023 2:23 PM
To: Jamie Gould <jgould at longshore.ca>; qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Exporting maps out of QGIS into Adobe Pro to create layered pdf files
Hi Jamie,
There are several tastes of pdf...
One of them is 'GeoPDF', a layered pdf, which you can create if you create a layout first in QGIS and then export that to pdf.
For the options see: https://us-east-2.protection.sophos.com?d=duif.net&u=aHR0cHM6Ly9kdWlmLm5ldC9wZGZvcHRpb25zLnBuZw==&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=c1doNm4vaE9oZ2EwTGVVWVZVU2JmZlJZd3luTWVjK05VbE90L2Z2ekxuUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
I've exported a simple map of two layers to: https://us-east-2.protection.sophos.com?d=duif.net&u=aHR0cHM6Ly9kdWlmLm5ldC9ubC5wZGY=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=cG1MR0tOOVBiRU05Y3NPUUJiY2trK29veExXbDBXdHNNYVQ3WFgxbjRxTT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
In most pdf viewers you can check/uncheck both layers, AND you can 'identify' objects there.
Can you check if that is what can be handled by your tools?
Regards,
On 7/12/23 22:10, Jamie Gould via QGIS-User wrote:
> Good afternoon,
> I am trying to export out my map in QGIS into Adobe Pro to create a layered PDF that I could toggle separate layers on and off.
> In the past I have done this through arcGIS, but I am currently at a company that uses geoSCOUT and you can't export a map in PDF form in geoSCOUT.  So, a former colleague told me that I can import shapefiles into QGIS and export the map to PDF that way - which works! However, when I bring the map into Adobe Pro, none of the separate layers show up and it's just a static PDF image.
> I just spent an hour with the Adobe help desk and the person I dealt with did all the things on the Adobe side and asked me to reach out to someone with QGIS to see if anyone has dealt with this before and how to get it working? Perhaps I have a setting off that I should have enabled, I'm really not sure.
> Any help is greatly appreciated. Thank you in advance,
> *Jamie**Gould*, *C. Tech*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info: https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
> Unsubscribe: https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230712/37db1ca2/attachment.htm>
More information about the QGIS-User mailing list
