[Qgis-user] Exporting maps out of QGIS into Adobe Pro to create layered pdf files
Jamie Gould jgould at longshore.ca
Thu Jul 13 14:44:07 PDT 2023
Thank you, everyone! I figured that part out with all your help.  I’m sure there is so much more to learn, and I’ll have to review the documents.
I know I will be looking to post a polygon along a wellbore at specific intervals. You cannot do this in geoSCOUT – well you can by creating a user database and create repeating tops to trick the program into doing that.  I’m thinking QGIS must be capable of posting a line, symbol, polygon etc along specified intervals?
Thanks!
Jamie
Sent: Thursday, July 13, 2023 1:49 AM
To: Jamie Gould <jgould at longshore.ca>
Cc: QGIS User <qgis-user at lists.osgeo.org>; Richard Duivenvoorde <rdmailings at duif.net>
Subject: Re: [Qgis-user] Exporting maps out of QGIS into Adobe Pro to create layered pdf files
Hi Jamie,
You do need to create a Layout. Once you have blank template, you can add elements to it. Right-click the empty page to go to page properties and set the page size. Then, from the lefthand toolbar use the add map icon. Enlarge the map item to fit the page.
You should see your map objects in it. You may need to change the scale of the map. And again in the toolbars theres a icon to move the content in the map.
I hope it helped.
Alex Neto
A quarta, 12/07/2023, 23:31, Jamie Gould via QGIS-User <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> escreveu:
Okay, I found those PDF Export Options - I had to create a Layout Template first, and then if I use the export to PDF it is successful, but TBH my template is blank and I am not sure how to bring things from my map into the template to print to PDF from there.  If I go back to the map screen and export the map, it is still exporting as a static unlayered image.
>A couple of things I noticed, in the Layout template the "append georeference information" is greyed out and automatically checked off and I cannot turn it on or off.
[cid:906d6182-487a-4c22-8614-795ac1e86244]
 >If I do the export to PDF in the map, when I toggle on "Create Geospatial PDF (GeoPDF)" the export fails
[cid:a0a11849-fb21-45d0-9973-a7e31dcd6b0a]
 >and I get this Warning error:
[cid:fff22269-7979-4f19-8605-560601068549]
Would anyone happen to know why? And if so, would these things be affecting my ability to export out layered pdf files?
Thanks again,
Jamie
From: Jamie Gould <jgould at longshore.ca<mailto:jgould at longshore.ca>>
Sent: Wednesday, July 12, 2023 2:49 PM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>; rdmailings at duif.net<mailto:rdmailings at duif.net> <rdmailings at duif.net<mailto:rdmailings at duif.net>>
Thank you so much for the quick response.
I'm pretty new to QGIS.  In the first link you sent, are those PDF Export Options set in Adobe or in QGIS, and if so, where do I find the settings to see if this how things are currently configured?
I was able to open your map and turn the layers on and off successfully.
Cheers,
Jamie
From: Richard Duivenvoorde <rdmailings at duif.net<mailto:rdmailings at duif.net>>
Sent: Wednesday, July 12, 2023 2:23 PM
To: Jamie Gould <jgould at longshore.ca<mailto:jgould at longshore.ca>>; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>>
Hi Jamie,
There are several tastes of pdf...
One of them is 'GeoPDF', a layered pdf, which you can create if you create a layout first in QGIS and then export that to pdf.
For the options see: https://us-east-2.protection.sophos.com?d=duif.net&u=aHR0cHM6Ly9kdWlmLm5ldC9wZGZvcHRpb25zLnBuZw==&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=c1doNm4vaE9oZ2EwTGVVWVZVU2JmZlJZd3luTWVjK05VbE90L2Z2ekxuUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
I've exported a simple map of two layers to: https://us-east-2.protection.sophos.com?d=duif.net&u=aHR0cHM6Ly9kdWlmLm5ldC9ubC5wZGY=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=cG1MR0tOOVBiRU05Y3NPUUJiY2trK29veExXbDBXdHNNYVQ3WFgxbjRxTT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
In most pdf viewers you can check/uncheck both layers, AND you can 'identify' objects there.
Can you check if that is what can be handled by your tools?
Regards,
On 7/12/23 22:10, Jamie Gould via QGIS-User wrote:
> Good afternoon,
> I am trying to export out my map in QGIS into Adobe Pro to create a layered PDF that I could toggle separate layers on and off.
> In the past I have done this through arcGIS, but I am currently at a company that uses geoSCOUT and you can't export a map in PDF form in geoSCOUT.  So, a former colleague told me that I can import shapefiles into QGIS and export the map to PDF that way - which works! However, when I bring the map into Adobe Pro, none of the separate layers show up and it's just a static PDF image.
> I just spent an hour with the Adobe help desk and the person I dealt with did all the things on the Adobe side and asked me to reach out to someone with QGIS to see if anyone has dealt with this before and how to get it working? Perhaps I have a setting off that I should have enabled, I'm really not sure.
> Any help is greatly appreciated. Thank you in advance,
> *Jamie**Gould*, *C. Tech*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
> List info: https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
> Unsubscribe: https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=c3813583a6ac458e9b68ca37023b1fee&s=AVNPUEhUT0NFTkNSWVBUSVbQ7Gfw17B4TVr-pQzE51zlED6SQ6KUI3my4CFDYCiGSw
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=11e31b89958f4f94bc2ba88213f71b98&s=AVNPUEhUT0NFTkNSWVBUSVZfSJOXKMOiAEqu2At0RT74hSanm25Ep2gRY7h-akot2A>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://us-east-2.protection.sophos.com?d=osgeo.org&u=aHR0cHM6Ly9saXN0cy5vc2dlby5vcmcvbWFpbG1hbi9saXN0aW5mby9xZ2lzLXVzZXI=&i=NjQ5Mzg2NjJmZjkyMWQxZWJjMzdlZTIy&t=MCt6dTdDVitKZWYrdzdkcVIzc2x5RVliQUt6Umh2RW5OanpxZEpJWFRtUT0=&h=11e31b89958f4f94bc2ba88213f71b98&s=AVNPUEhUT0NFTkNSWVBUSVZfSJOXKMOiAEqu2At0RT74hSanm25Ep2gRY7h-akot2A>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230713/1a71708f/attachment.htm>
More information about the QGIS-User mailing list
