[Qgis-user] draw polygon
Richard McDonnell richard.mcdonnell at opw.ie
Tue Jul 25 03:31:54 PDT 2023
Hi Salvatore,
You could try:
1.       Selecting/Highlighting Polygon 1, which should also highlight the area you want to cut into area 4.
2.       Using the Split Features tool, you can then create a cutline to clip it successfully, something like what’s shown below in green, should work.
The polygons 2 and 3 shouldn’t be altered, as the Split feature tool will only alter the Selected/Highlighted Polygon 1
[cid:image001.png at 01D9BEEB.9C9A7320].
Hope that helps.
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Prisma via QGIS-User
Sent: 24 July 2023 10:59
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] draw polygon
Hello,
I need to draw a polygon, the blue one indicated in the figure below:
[cid:image002.png at 01D9BEEB.9C9A7320]
I tried with the split features toll but I received an error. Any solution?
Thank you.
Regards,
Salvatore
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/6ff2f0b2/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/6ff2f0b2/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/6ff2f0b2/attachment-0003.png>
More information about the QGIS-User mailing list
