[Qgis-user] draw polygon
Prisma salvatore.mellino at prismambiente.it
Tue Jul 25 05:51:26 PDT 2023
Hello Richard,
it works!
Thank you!
Il 25/07/2023 10:36, Richard McDonnell ha scritto:
> Hi Salvatore,
> You could try:
> 1.Selecting/Highlighting Polygon 1, which should also highlight the
> area you want to cut into area 4.
> 2.Using the Split Features tool, you can then create a cutline to clip
> it successfully, something like what’s shown below in green, should work.
> The polygons 2 and 3 shouldn’t be altered, as the Split feature tool
> will only alter the Selected/Highlighted Polygon 1
> Hope that helps.
> Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> /FRM Data Management/
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> https://https://gov.ie/opw <https://www.opw.ie>
> Email Disclaimer:
> <https://www.opw.ie/en/disclaimer/>
> *From:*QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
> *Prisma via QGIS-User
> *Sent:* 24 July 2023 10:59
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] draw polygon
> Hello,
> I need to draw a polygon, the blue one indicated in the figure below:
> I tried with the split features toll but I received an error. Any
> solution?
> Thank you.
> Regards,
> Salvatore
Salvatore Mellino
Dottore di Ricerca/Ph.D.
Prisma s.r.l. - Progettazione e Realizzazione Impianti e Servizi di Monitoraggio Ambientale
Via Monsignor Bonaventura Gargiulo, 13 - 80065 S.Agnello (NA)
Tel./Fax: +39 081 8072476
www.prismambiente.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/1b03ba1e/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/1b03ba1e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/1b03ba1e/attachment-0003.png>
More information about the QGIS-User mailing list
