[Qgis-user] Removal of overlap geometries within the same layer - merge to largest neighbor polygon
Wouter Impens wouter.impens at gmail.com
Tue Jul 25 04:05:38 PDT 2023
Hi Andreas,
You could do a ' self-intersect'  of the polygon layer, calculate the area,
select polygons under specific area (assuming they're small overlaps) and
run the ' eliminate selected polygons' tool.
The GRASS tool v.clean offers some solutions too.
Greetings
Wouter
Op di 25 jul 2023 om 12:02 schreef Andreas Neumann via QGIS-User <
qgis-user at lists.osgeo.org>:
> Hi,
> A friend of mine has a dirty input data set with lots of overlapping
> geometries (within the same layer) and asked me if there is a tool within
> QGIS to automatically remove the overlaps and assign the overlapping area
> to the neighbor polygon with the largest area.
> The solution was surprisingly hard to find, although I am pretty sure
> there are multiple combinations of algorithms that would solve the problem.
> Here is the solution I came up with: https://github.com/qgis-ch/overlap_removal/tree/main
> - perhaps you have better ideas - more elegant solutions?
> Wouldn't it be great if QGIS had a processing tool to solve this overlap
> cleaning within the same layer "out of the box" without having to use a
> graphical model or a more or less complicated sequence of algorithms in the
> processing toolbox? Apparently, ArcGIS has such a tool ...
> Saga and GRASS also might have such tools - but I couldn't get the SAGA
> based QGIS plugin "Dissect and dissolve overlaps" (
> https://plugins.qgis.org/plugins/dissect_dissolve_overlaps).
> The same problem exists for automatically filling small gaps in the
> polygon data set ...
> Andreas
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230725/2ac5b624/attachment.htm>
More information about the QGIS-User mailing list
