[Qgis-user] Clipping ecw to mask not working
Andrea Giudiceandrea andreaerdna at libero.it
Wed Jul 26 02:50:56 PDT 2023
> Michael Dufty MDufty at mbsenvironmental.com.au
> Tue Jul 25 22:02:06 PDT 2023
> I'm having issues trying to clip ecw images to a mask layer.
Hi Michael,
what is the Operating System you are running QGIS on? Can you display
the ECW layer in QGIS? Which is the format of the output raster layer
set in the processing algorithm? What is the full execution log of the
processing algorithm? What is the GDAL library version used by QGIS on
your system? Does the GDAL library support the ECW format in your system?
The "Clip raster by mask layer" processing algorithm is actually
executed by the gdalwarp utility of the GDAL/OGR library.
Have you tried to directly execute the gdalwarp command (as generated by
the processing algorithm) in the shell of your system?
Best regards.
Andrea
More information about the QGIS-User mailing list
