[Qgis-user] Technical specifications
Sebastian Gutwein bas at rdgland.com
Fri Jun 2 11:04:07 PDT 2023
Hello,
As it was not clear exactly what the needs of the department were I wanted
to offer an alternative perspective.
I have a small planning and design firm and we utilize QGIS healily on all
of our computers. I also teach GIS at a local masters program in planning.
While I agree with the specs put forward by the other respondents if you
are engaging in large geoprocessing tasks or if you want to make sure that
the computer you purchase is somewhat future proof. However, my students
and I do an amazing amount of processing and map creation on much less. I
have 16 GB of ram on my 6 year old windows machine and with the right
optimizations and able to run state wide geoprocessing tasks (I imagine you
could even have less RAM on linux). Some of my students this year somehow
ended up with 8 GB of ram on windows and if they are careful about the
number of programs they have open can easily run town scale GIS processing.
On Fri, Jun 2, 2023 at 1:35 PM KEITA Mamady kobélé via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Thanks to all for these useful tips and suggestions.
> The beneficiary service has a limited GIS Capability and we are preparing
> a training program as well.
> The internet is not that strong, so giving priority to desktop softwares.
> A cloud will be USED mainly for storage purpose, not really for WMS.
> Many thanks,
> Mamady
> On Fri, Jun 2, 2023, 11:39 AM Richard McDonnell <richard.mcdonnell at opw.ie>
> wrote:
>> Hi All,
>> I would like to just throw my two cents in on this.
>> If Raster processing is envisaged, push it out to 32 minimum 64
>> recommended and 128 if you can stretch.
>> As for Processors, you need as many Threads as you can afford, with a
>> good base clock.
>> I would agree with the use of SSD I would also recommend the use of a
>> good PCI/NVME drive for boot, operating system and software, but also a
>> second Solid State drive for storage of data you are working on. It's best
>> not to be processing over a network, if at all possible.
>> Two decent screens are a must and I agree that a good Mouse and Keyboard
>> are almost always overlooked.
>> In relation to Operating System, Its personal preference. Both Linux and
>> Windows are stable, with varying degrees of involvement.
>> If you go down the windows operating system route, I would advise using
>> the OSGeo4W installer to install everything. It keeps everything working
>> well in one environment, installing all dependencies. It even making
>> running GDAL or Python commands from Command line easier as it has its own
>> OsGeo4w Shell. Updating and installing additional tools and library's is
>> also a breeze. BIG SHOUT OUT TO THE DEVS!!!
>> I hope that helps!!
>> Kind Regards,
>> Richard.
>> Richard McDonnell MSc GIS, FME Certified Professional
>> FRM Data Management
>> Oifig na nOibreacha Poiblí
>> Office of Public Works
>> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
>> Jonathan Swift Street, Trim, Co Meath, C15 NX36
>> M +353 87 688 5964   T +353 46 942 2409
>> https://gov.ie/opw
>> To send me files larger than 30MB, please use the link below
>> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
>> Email Disclaimer:
>> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
>> FRM Data Management
>> https://www.opw.ie
>> Email Disclaimer: https://www.opw.ie/en/disclaimer/
>> > -----Original Message-----
>> > From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Greg
>> > Troxel via QGIS-User
>> > Sent: 02 June 2023 11:51
>> > To: Sébastien LAGARDE via QGIS-User <qgis-user at lists.osgeo.org>
>> > Cc: KEITA Mamady kobélé <kobele at gmail.com>
>> > Subject: Re: [Qgis-user] Technical specifications
>> > Sébastien LAGARDE via QGIS-User <qgis-user at lists.osgeo.org> writes:
>> > Keep in mind that I have not used QGIS in a super serious way, and
>> haven't
>> > even tried to figure out how much resources it needs, other that on my
>> > desktop (a hand-me-down machine that was high end in 2014, with 24 GB
>> > RAM), it runs fine.
>> > There's a huge question not asked or answered, which is about operating
>> > system.  I personally would not even consider using Windows, but that's
>> me
>> > > GIS operator Workstation (standard use)
>> > >   *   Intel i5 or higher (12th gen) or AMD equivalent
>> > >   *   16 Gb RAM
>> > >   *   512 Gb HD but only SSD or even better PCI / NVME drives
>> > >   *   Small dedicated graphic card (any entry level card with 2-4 Gb
>> of
>> > dedicated memory)
>> > >   *   1 Gb network
>> > This seems reasonable, but:
>> >   Knowing how much disk one needs requires a plan of how the system is
>> >   going to to be used.  With most data in a database, the question would
>> >   be then how much imagery you will have locally.
>> >   In 2023, I can't recommend buying any computer for desktop use with
>> >   less than 32 GB of RAM.  Almost always, my computers have become
>> >   unusable due to low RAM, before anything else, usually after more than
>> >   10 years.  If it is easily possible to upgrade, and there's evidence
>> >   that running QGIS and other things at once (browser, mail client, ?)
>> >   really fits in 16 GB *without any need to page anything back in*, then
>> >   maybe that's ok.  But it strikes me as likely too little.  (If it's
>> >   not easily possible to upgrade, buying a 16 GB computer is just plain
>> >   unwise IMHO.)
>> > > GIS analyst Workstation (double up) :
>> > >   *   Intel i7or higher (12th gen) or AMD equivalent
>> > >   *   32Gb RAM
>> > >   *   1 Tb HD but only SSD or even better PCI / NVME drives
>> > >   *   dedicated graphic card (4 Gb of dedicated memory)
>> > >   *   1 Gb network
>> > Again I might go higher in RAM.
>> > > And don’t forget to include in your quotations good interfaces
>> > > (screens = min of 2*24 “, good keyboard and High DPI mouse), we tend
>> > > to neglect them and use what comes was standard with orders but good
>> > > large screens and a comfortable mouse does change your long term
>> > > experience !!
>> > Great advice.  I'm running with one monitor now but this would be a big
>> > improvement.
>> > _______________________________________________
>> > QGIS-User mailing list
>> > QGIS-User at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230602/e12b69ee/attachment-0001.htm>
More information about the QGIS-User mailing list
